malcster
by malcster » Fri Jan 04, 2013 4:03 pm
anything available here in NZ? for a garrett t25.
cheers.
1998 NB MX5 RS TURBO.
by punkoutnz » Fri Jan 04, 2013 4:25 pm
I got one for a t3 housing on mine and it fits nicely. Got it from scarles.
malcster
by malcster » Fri Jan 04, 2013 4:58 pm
cheers for that ..i think t25-t3 ones fit.
by Snapfrozen » Fri Jan 04, 2013 5:21 pm
Done your research? They can severely hinder the life of the housing/compressor wheel and the gains for a street car might be minimal
malcster
by malcster » Fri Jan 04, 2013 5:57 pm
ok..havent done a lot of research..did wonder about that as seems to keep the heat in the turbo and maybe i should stick with my stainless heat shield?
by Snapfrozen » Fri Jan 04, 2013 6:16 pm
For a race car where you need the power/heat they're great, but you will end up decreasing the life of a cheap turbo by about half, or an expensive turbo by about 10-30%. The heat will also eventually damage the exhaust components too. Just heat shield what you can
malcster
by malcster » Fri Jan 04, 2013 6:22 pm
o.k..good advice..its a garret t25 with hks internals so may just stick with the heat shield for now.
by punkoutnz » Fri Jan 04, 2013 7:03 pm
Who told you they're bad? Because I've never had an issue with mine, and several friends run them, again with no issues. It has stopped the paint peeling from my bonnet though...
by Snapfrozen » Fri Jan 04, 2013 7:06 pm
It is very common knowledge that they lead to premature wheel/housing failure. In saying that, they only speed it, they don't directly cause it, so it might never happen, or it might do it 3 times in a row. Depends on temps, size, etc... Google turbo beanie/blanket and failure.
by SLYDIT » Sat Jan 05, 2013 5:41 pm
dont wrap the turbo. just sheild everything around it...have a look how i did it onmine. wrap the heater hoses/lower rad hose/brake line and put a piece on the bonnet too.
http://www.cardomain.com/ride/264041/19 ... -5/page-6/
malcster
by malcster » Sat Jan 05, 2013 6:10 pm
i guess its more about keeping the heat off the bonnet.
i have ordered 1x of the scarles one to try and do have the heatshield as well but just found a couple of the stays broke so blanket will be better from this veiw point.will leave off heat shield for now and see how it goes.
by SLYDIT » Sun Jan 06, 2013 6:39 pm
I riveted a bit of repco heat shield to my bonnet. Works great. I have about a 3 to 5 mm gap between it and the bonnett
by Mad Kiwi » Sun Jan 06, 2013 10:09 pm
I looked in to these as well. The examples of flaking downpipe metal and failed turbos put me off in a hurry. Ended up using Flyin Miata louvers instead.
These made a MASSIVE difference to underhood temps especially around the intake area.
I know cause I checked before and after with a indoor / outdoor thermostat from the warehouse
Users browsing this forum: Google Adsense [Bot] and 36 guests
