Wideband sensor
Wideband sensor
Post by warrior » Mon Dec 17, 2012 8:10 pm
I have a 1.6 na with a jackson racing supercharger, it is fuelled by a powercard piggyback system. I have a narrow band gauge in the car at the moment and have set the fuelling (with advice from TRACKDOG RACING) with that.
I was going to get the car tuned on the dyno but i,m sure I can get it perfect with a wideband sensor/gauge.
I know most people will say "dyno the car" but the powercard is very simple and I am fairly sure I can get it 99% right with the wideband and not have to pay for the time on the dyno.
What are your guys thoughts?
wideband $250.00.....dyno $??????????
Post by WideOpenThrottle » Mon Dec 17, 2012 8:17 pm
If you absolutely know what you are doing fine!... otherwise dyno will give you a way better/safer tune.
Wideband sensor
Post by jif » Tue Dec 18, 2012 10:05 am
I went the wideband+knocksensor+roadtune option, absolutely no problems. Tune went from <10:1 rich (FlyinMiata default map) to 12:1 and it perked up quite a bit as a result.  Also means you can do things like tune in a nice over-run crackle :)  and make occasional re-tunes for things like bad gas, change in weather, altitude etc.
Good for a 80-90% good tune, that last little bit on the ragged edge ... not so much.
HTH.
Re: Wideband sensor
Post by sprsta » Tue Dec 18, 2012 12:07 pm
jif wrote:I went the wideband+knocksensor+roadtune option, absolutely no problems. Tune went from <10:1 rich (FlyinMiata default map) to 12:1 and it perked up quite a bit as a result.  Also means you can do things like tune in a nice over-run crackle :)  and make occasional re-tunes for things like bad gas, change in weather, altitude etc.
HTH.
this^^^
And if your only tuning a power card i wouldn't waste $ on dyno time
Post by warrior » Tue Dec 18, 2012 2:47 pm
Yeah thats how I was thinking.....the powercard is very simple and I have it pretty close from just my narrowband and the advice from TRACKDOG. Like I said $250.00 and I have the wideband forever.
Does anyone know???? I have a heated oxygen sensor because of the aftermarket headers....is a wideband sensor heated or not?
Post by Angreal » Tue Dec 18, 2012 4:07 pm
I think the heated ones started from the NA8Cs onwards. Google can confirm but I will check later tonight (probably midnight when I start shopping on yahoo.jp)
Post by warrior » Tue Dec 18, 2012 4:13 pm
Yeah the early ones were not heated but I put one in because of new headers. What I need to know is, is a wideband sensor heated? I assume it would have to be?
What type of guage/sensors are you guys using?
Post by Mad Kiwi » Tue Dec 18, 2012 4:21 pm
My innovate one is heated and I "believe" all wide bands are......
Post by Angreal » Tue Dec 18, 2012 4:45 pm
Mad Kiwi wrote:My innovate one is heated and I "believe" all wide bands are......
I'm pretty sure that all widebands are heated... You might stumble across one and prove me wrong though :p
Wideband sensor
Post by jif » Tue Dec 18, 2012 5:15 pm
yes 99% sure a WBo2 is heated - because the voltage response varies with temperature, it needs to be within a certain range to be useable/reliable.
go for it ... at nearly 3x the price (a few years back) it seemed like a decent deal to me :D
Post by sprsta » Tue Dec 18, 2012 7:59 pm
just watch your grounds when wiring in the innovate
if you have any issues at all, itll be to do with the grounding
Post by warrior » Tue Dec 18, 2012 8:15 pm
cheers guys....looks like its sold.
Post by SLYDIT » Tue Dec 18, 2012 9:27 pm
most wideband controllers out \put 2 voltages...a narrow band and wide band so you use just the wideband sensor and feed its narrow signal into the ecu and the wide into whatever you want to read/display it
Post by Mad Kiwi » Wed Dec 19, 2012 12:15 pm
interstingly, I spoke to link and they said it didn't make enough difference on the Miata Link or the other link unit I had to even worry...
Was rather disapointed with that.....I believe the Link 2,3 and 4 do use the narrow / wide band info though....
Wideband sensor
Post by jif » Wed Dec 19, 2012 1:46 pm
yep, but with a WBo2 you can actually tune for something other than stoichiometric as the closed-loop target :]
Post by CordedBowl » Wed Dec 19, 2012 3:07 pm
As a side note; I take it the Innovate is the best bang-for-buck sensor/gauge at the moment?
I'm looking to get one for my turbo build 8)
Post by warrior » Wed Dec 19, 2012 4:37 pm
That is what I am looking at as well
Post by SLYDIT » Wed Dec 19, 2012 8:06 pm
yup get an innovate. they have a good user forum too
Post by sprsta » Wed Dec 19, 2012 10:13 pm
Mad Kiwi wrote:interstingly, I spoke to link and they said it didn't make enough difference on the Miata Link or the other link unit I had to even worry...
link NZ have no records of the FMLink they are two totally diferent systems!
a fmlink will take a 5v wbo2 signal a link nz miatalink will only perform the basic functions of a G1 link
flyin miata exported a whole bunch of miatalink's and made their own chip for it
linknz will not provide support
