Airflow Sensor
Airflow Sensor
Post by Donovan » Thu Nov 22, 2012 8:26 am
Is the airlflow sensor different between a 1.6 and a 1.8 NA? My brother has a 93 1.8 and the air flow sensor is stuffed, there is one on trademe from a 1.6, so just want to find out whether it can be used on his car or not before I get it.
Post by Angreal » Thu Nov 22, 2012 9:02 am
Completely different - My 1.8 one has a hot wire in it, not sure how the 1.6s work but they're not interchangeable.
Post by Donovan » Thu Nov 22, 2012 9:07 am
Pooos
Nearly too late
Post by Nearly too late » Thu Nov 22, 2012 9:23 am
The 1.8 uses a mass air flow type while 1.6 uses a vane type two different things all together
Post by chris » Thu Nov 22, 2012 11:36 am
Try asking Mazda NZ :)
Post by brownie » Fri Nov 23, 2012 12:38 am
1.8 is the same as lots of mazdas around the same year B6BF type
V6 lantis,4 cyl lantis,Familia (1.8 BH model)
Post by Snapfrozen » Fri Nov 23, 2012 8:14 am
A lot of the RX7 ones work to. Google knows which series
