Lower Radiator hose...
Post by Ian » Tue Nov 13, 2012 9:34 pm
Hi guys...
About to buy a 1 piece NB lower radiator hose to replace the original 2 piece lower hose on my NA. I believe them to be a straight swap? Anyone able to comment?
Post by brownie » Wed Nov 14, 2012 12:01 am
yep,Straight swap,Does mean you have a longer hose to weaken over time,but then no steel pipe in the middle to rot out,50/50 call to say you will gain anything.
Silicone hose's might be a better way to go if you go the one piece,stronger and will not collapse as easy being longer,then again never sold a NB lower pipe thru work before either.
Post by WideOpenThrottle » Wed Nov 14, 2012 8:10 am
Put one on my NA and fits nicely..got it from Mazda in Glenfield for $15.00.
Post by Ian » Wed Nov 14, 2012 3:31 pm
Cheers guys...2 less joins plus weight saving(?) plus precautionary maintenance while steering rack is out was the motivation for the change to the NB hose. Would consider a silicone hose if I could locate one at a reasonable price - any suggestions?????
Post by REDBEN » Wed Nov 14, 2012 5:08 pm
Ian wrote:Cheers guys...2 less joins plus weight saving(?) plus precautionary maintenance while steering rack is out was the motivation for the change to the NB hose. Would consider a silicone hose if I could locate one at a reasonable price - any suggestions?????
http://www.corksport.com/samco-miata-ra ... -1.8l.html
Post by Angreal » Wed Nov 14, 2012 5:24 pm
I'll stick with the $15 option...
