My car has a rattle coming from the gear shift/box when in 6th (and to a lesser extent 4th- I.e. with the gearstick towards the rear).
It's not a loud rattle, it sounds similar to something vibrating in the glove box or stereo compartment (i.e. slightly plasticky rattle)- I haven't taken the trans tunnel cover off yet to investigate it but does anyone have any clues as to what it may be?
{NB} Rattle in 6th and 4th
Found the issue- Both rubber seals (the one which seals the trans tunnel from the cabin and the one which seals the top of the transmission) were cracked- When the gearstick was facing back, the crack was opened up letting gearbox/road noise into the cabin.
I've ordered both seals from Mazda (not exactly cheap though!) so that can be this weekends job.
