Difference between NA and NB Tophats
Post by Furai » Wed Oct 10, 2012 5:47 pm
Found a nice image detailing the difference.
21mm Lower if used with NA shocks.
http://cdn.mkimg.carview.co.jp/carlife/ ... 608fa55912
Compression
aidwano
Post by aidwano » Wed Oct 10, 2012 10:33 pm
You won't quite get 21mm lower if you use NB hats on NA shocks due to needing to reduce the height of the rubber bushes though.
I ended up probably 10-12mm lower when I did it.
EDIT- unless you use a fancy nut that can go down inside the bushes, then you might
Post by Furai » Thu Oct 11, 2012 8:51 pm
aidwano wrote:You won't quite get 21mm lower if you use NB hats on NA shocks due to needing to reduce the height of the rubber bushes though.
Wouldnt it depend on which bush you reduce more?
aidwano
Post by aidwano » Thu Oct 11, 2012 9:55 pm
I guess so. I had to chop over half off both bushes though
Post by Angreal » Thu Oct 11, 2012 10:26 pm
Would the custom tophat sprsta mentioned a while back get your car lower to the height you'd be more comfortable with? Just a thought.
http://www.mx5forum.co.nz/viewtopic.php?t=10281
