Rear Adjustable camber arms's
Has anyone tried or using the rear adjustable camber arm's from Redline performance?
Ben
Ben
You dont need adjustable camber arms on an mx5!! the eccentric bolts in the upper and lower control arms are adjustable from factory if you need more adjustment get offset eccentric bolts
Here
http://www.iscracing.net/miatasuspension.html
Here
You also won't be able to certify them as it will throw you MILES outside the camber allowance (And for a WoF, you will have to if your WoF guy isnt a retard or the "let it slide" kind).
I've had to return about 3-5 pairs of camber arms from redline, each set lasted 1 race or less on my EG before they failed or bound (Yes, I used copper grease). Wouldn't touch them
If you really want the extra adjustment you could go to the V8 Roadsters tubular arms from FM.
http://www.flyinmiata.com/index.php?dept=120
...or fabricate your own...Euen wrote:If you really want the extra adjustment you could go to the V8 Roadsters tubular arms from FM.
