Lightening stock flywheel
halberd
Post by halberd » Mon Oct 01, 2012 11:03 pm
Is it possible?
Is it worth it?
Also as a side note my clutch has just shit itself, are there any decent aftermarket clutches or should I stay with OEM? My budget is student mode so best value for money is required
'91 Eunos Roadster
Brainflex
Post by Brainflex » Tue Oct 02, 2012 7:12 am
There is a guy selling Exedy clutches for $190 on Trade Me. Best price I have found. There is also someone selling a Ginken sports clutch for $380.
Post by warrior » Tue Oct 02, 2012 9:04 am
no, dont lighten your flywheel. buy a new one
Post by warrior » Tue Oct 02, 2012 9:06 am
and if it is a standard car with standard horsepower stay with oem clutches
Post by Kieran » Tue Oct 02, 2012 10:27 am
If your prepared to spend some cash you could get a Heavy duty clutch, street disk Pressure plate and a streetlite flywheel it will act similar to oem on the road and take alot more abuse and be more fun
Post by WideOpenThrottle » Tue Oct 02, 2012 10:41 am
Put in an 1800 one [clutch & flywheel] at least while you have the chance....i have an 1800 HD exedy now in mine with no issues.
If you ever increase HP then its one less thing to worry about.
Post by SLYDIT » Tue Oct 02, 2012 7:21 pm
before turbo i had a lightened 1600 flywheel and it made a noticeable difference.
if you are replacing the clutch then its a worthwhile mod.
Post by Mr. Shine » Tue Oct 02, 2012 10:06 pm
I have a used Toda Racing flywheel to suit NA6 that I could be willing to part with if you'd like to PM me.
Post by brownie » Tue Oct 02, 2012 11:50 pm
Get the TODA,Best thing i did with mine,used standard clutch,Really wakes them up !!.and get the chip done from Don at Autoways,or you keep hitting the limiter easy
Post by Growler » Wed Oct 03, 2012 2:18 pm
I took around 2 pounds off my standard one, then balanced the flywheel and clutch as one unit.
This was about 8 years ago and I haven't had an issue at all.
The only grumble I would have, is that it has lost a little bit of torque from the flywheel down low when you are trying to manuouver out of a carpark or garage etc. But it does make a difference when building the revs up!
