Suspension and track times Disscusion
Could you please help me understand? My initial thought towards it would be the driving style, weight balance and attitude under braking and acceleration is different meaning a totally different setup and driving style.13r wrote:Lol at the lack of understanding... I know what you meant Snappy
I know I sound like a knob but I ask for the purposes of learning not to annoy anyone.
No, I think you've read too far into what he said.Furai wrote:Could you please help me understand? My initial thought towards it would be the driving style, weight balance and attitude under braking and acceleration is different meaning a totally different setup and driving style.13r wrote:Lol at the lack of understanding... I know what you meant Snappy
His old civic handled like it was on rails and I believe that's what he's hoping this set up will provide (which it has).
No body roll, and grippy as fuck around corners.
Ahhh thanks, I always go a bit to into detail13r wrote:No, I think you've read too far into what he said.Furai wrote:Could you please help me understand? My initial thought towards it would be the driving style, weight balance and attitude under braking and acceleration is different meaning a totally different setup and driving style.13r wrote:Lol at the lack of understanding... I know what you meant Snappy
Its a good thing and a bad thing!
This13r wrote:No, I think you've read too far into what he said.Furai wrote:Could you please help me understand? My initial thought towards it would be the driving style, weight balance and attitude under braking and acceleration is different meaning a totally different setup and driving style.13r wrote:Lol at the lack of understanding... I know what you meant Snappy
My EG actually oversteered slightly. I had a 28mm swaybar up front, nothing on the rear. The only thing factory on my suspension was my front LCA's. Car was amazing to drive.
My roadster has about the same amount on turn in from what it feels like, although with less power, I'm not sure how it will handle once turbo'd.
Gotta get the finances recovered, get a lip, and then look into getting my springs shortened to drop it about another half inch on front and rear, should only be 2 coils roughly. Then will come the wider wheels, sways and rubber and probably flares to accomodate the wheels. Then turbo and will go from there
Theres a difference between cutting springs bei and getting springs professionally shortened.
Obviously it only oversteered under braking and light off, that was how I liked to drive it though, and it wasnt bad, I think I only spun once or twice in my entire history of track driving, both were on my first time on full slicks, prefer semi's personally. If it was oversteering not on throttle or braking then I would say you are just taking a corner too fast
Coilover setup that is comparable would be about $2200. Quite prepared to run aftermarket shocks, with aftermarket springs, that have been revalved t suit the height and stiffness I want.chris wrote:Or just spend a little bit more and get coilovers..
No difference between that and coilovers other than the fact I can change the height whenever.
Well an equivalent Bilstein setup would be easily a few thousand dollars plus cert.
In this document it states replacement springs are not heated or cut, it doesnt seem to matter who did it its not allowed unless certified Im guessing?
http://www.lvvta.org.nz/documents/suple ... eshold.pdf
Basically. Spring compression is always an option too but that would change the ratesFurai wrote:Well an equivalent Bilstein setup would be easily a few thousand dollars plus cert.
Yeah preload would probably make your setup bouncier or smoother depending on if the valving you have is more suited to stiffer springs which it sound like it is.Snapfrozen wrote:Basically. Spring compression is always an option too but that would change the ratesFurai wrote:Well an equivalent Bilstein setup would be easily a few thousand dollars plus cert.
But yes, this was my main reason. These will have great resale value, theyll be worth approx 1500 new as they are for the revalving, springs, shocks and circlip work done to them. So I'm not concerned about selling them and getting coilovers when I cert for my turbo buildFurai wrote:Well an equivalent Bilstein setup would be easily a few thousand dollars plus cert.
I wouldnt be worried about cut springs and Whether you can cert them or not, considering you're already running height adjustable shocks without a cert, whether the springs are cut is not an issue cos it's illegal anyway.
When I was chatting to the Autolign guys at Albany about trying to find some hard to find Springs for my Tein Coilovers, they said an option would be to get Bilstein's with the circlips, and then apparently they do a tread kit or something that you remove the circlip and can put in platforms that turn them into a sort of coilover, think it was about $800-$900 or something?? Don't quote me on the price, cause my memory is shocking, but it was cheap.Snapfrozen wrote:Coilover setup that is comparable would be about $2200. Quite prepared to run aftermarket shocks, with aftermarket springs, that have been revalved t suit the height and stiffness I want.chris wrote:Or just spend a little bit more and get coilovers..
Mad_Kiwi was also running HSD coilovers in his (before getting Keith's Koni's) which I think are about $1500, and a few of the reviews that I read about them said that they were not too bad. Dodson do these.
Thing is, theres no point in me buying cheap coilovers. They are going to get fucking raped on the track. Bilsteins are rebuildable, they have the exact rates I want, and theyre brilliant quality (no point putting cheap sleeves on them, I can get the desired height without coilover sleeves).
My next option would be to look at the middle to top Fortune Auto coilovers with custom rates on them, but until I hit the limit with how I can perform driving on these, theres no point.
I was doing 1:11's at Puke and 1:20's at Taupo in a near stock engined car, run to your limit. THEN spend money to make yourself faster, this poor bitch has barely seen the track yet, let alone hitting the limit driving her
Er, I take it that you were running the full A1GP track for those times at Taupo? Puke time seems pretty quick, I thought the NZ GT class was running at 1:05's or something like that, but Keith Jones would know more about that than me, I haven't run around Puke in a long time.Snapfrozen wrote:Thing is, theres no point in me buying cheap coilovers. They are going to get fucking raped on the track. Bilsteins are rebuildable, they have the exact rates I want, and theyre brilliant quality (no point putting cheap sleeves on them, I can get the desired height without coilover sleeves).
I'd be very scared to try reach the limit in Donovan's carSnapfrozen wrote:My next option would be to look at the middle to top Fortune Auto coilovers with custom rates on them, but until I hit the limit with how I can perform driving on these, theres no point.
