by Furai » Thu Aug 30, 2012 3:37 pm
So I am looking to get the best out of my suspension, Im setting up to use revalved HD Bilsteins with 8Kg front springs and 6Kg rear. I just came across these Cusco Pillow ball upper mounts and noticed the RS Aizawa car uses them.
http://page12.auctions.yahoo.co.jp/jp/a ... p302033064
Im guessing these are just an upper mount similar to that of a coilover for a non coilover shock setup? What advantages are there if any?
by sprsta » Thu Aug 30, 2012 7:28 pm
i wouldnt bother with them
itll only transfer NVH to you and wont add any benefit
it may be usefull in a mcpherson strut style type set up as the shocks play more part in the setup
the small amount you may gain from them is not worth the money
by Angreal » Thu Aug 30, 2012 7:59 pm
Get some poly bushings instead?
- I only think 5.
by warrior » Thu Aug 30, 2012 8:09 pm
I agree, will make no diffrence
