crunchy 2nd? good news
na6*dori
Post by na6*dori » Sat Aug 18, 2012 12:15 am
i stripped down my 5 speed to find... 2nd gear, 2nd gear synchro, synchro hub and sleeve all stuffed...
Rang mazda dealership as the people we delt with through work had no listings for the na, and to my suprise i managed to pick up everything i need for less than 150 dollars.
So if anybody else is postponing the inevitable best to give them a ring, only posted this purely because ive never experienced a dealer thats cheap haha
Post by Furai » Sat Aug 18, 2012 7:33 am
Yeah Mazda is surprisingly cheap, I buy quite a bit off them. Sealed beams only $30, new antenna $45, they are pretty good.
halberd
Post by halberd » Sun Sep 02, 2012 11:23 pm
How hard is it to strip down a gearbox?
Mine crunches going into 1st most of the time, and sometimes 3rd. I'm too hard on her I think. Also it's developing a high pitched whine when I really push it.
I feel like in the last month or so my car is falling apart around me.
'91 Eunos Roadster
na6*dori
Post by na6*dori » Mon Sep 03, 2012 6:45 pm
not the hardest thing in the world, but if you havent done one before id say gat a workshop manual just in case
Post by SLYDIT » Mon Sep 03, 2012 6:47 pm
id be keen to replace the input shaft bearing...
do you know a good how to or manual for rebuiiding these?
Post by Angreal » Mon Sep 03, 2012 7:59 pm
Is there any simple way to make my 5th gear lower? Like changing sprockets on a bike simple?
Post by SLYDIT » Mon Sep 03, 2012 8:22 pm
this may help the 5th gear question.
http://www.solomiata.com/Drivetrain.html
Post by jif » Mon Sep 03, 2012 9:45 pm
On 3 September 2012 19:59, Angreal <mx5talk@mx5forum.co.nz (mx5talk@mx5forum.co.nz)> wrote:
taller tyres ?  Affects all the gears tho ;)
Post by Angreal » Mon Sep 03, 2012 10:36 pm
That s2000 info sounds interesting... Guess I need to keep reading now.
I guess it is possible to do, just rather beyond what my abilities are :( ah well, one can wish right? :D
halberd
Post by halberd » Tue Sep 04, 2012 10:53 am
na6*dori wrote:not the hardest thing in the world, but if you havent done one before id say gat a workshop manual just in case
I've got the enthusiasts manual (the Veloce one) and it seems pretty detailed, do you reckon that would be enough?
Also are any special tools required, and if so how much do they cost?
Thanks for your help
'91 Eunos Roadster
