Spring Rating
Spring Rating
Is there any way to tell what rating a spring is if the part numbers have all worn off them.
I have a set of 12kg rated springs from Keith that I am going to try on the front, and was intending on putting the existing front ones to the back (until I get myself a set of 8kg ones for the rears) as I thought in theory they would be beefier, but looking at the two sets, they look pretty much the same.
Slightly off topic, but..
from what I understand, the shocks in the coilover are matched to specific spring rates. A lot of coilovers have a specified tolerance to how stiff/soft a spring rate you can run. Usually +/- 2kgmm from whatever it comes with.
Too stiff or too soft may lead to premature wear on the shock's seals.
Someone correct me if I'm wrong. Only felt the need to pull this up because most street coilovers for MX5 I think are rated at 8f/6r. Running 12kgmm springs might be ok in the short run.
Er, yeah, I have figured out that my shocks aren't most likely going to be a lifelong part of the car, so just trying to get the best out of them in the mean time.
Just hoping that they hold out long enough for me to save up for these.
http://www.good-win-racing.com/Mazda-Pe ... 5Race.html
So I sat down and worked out the spring rate, based around that online calculator, and provided my measurements aren't too dodgy (which the most likely are) and my maths is correct (which it most likely isn't) I have the old front springs rated at 7.32kg/mm and the rears at 4.977kg/mm, which I suppose sounds about right. But looking at them, I can't tell the difference.
I suppose the acid test will be taking the measurements from the new springs and seeing if they work out to be about 12kg/mm
Got the springs rated, seems my calculations and measuring were a bit off. So the old front ones that I am moving to the back are rated at 5.7kg/mm, the old rear ones are at 4.5kg/mm and Keith's ones that I am going to try out are 11.6kg/mm (sorry Keith, not the full 12kg, and they "twinked" one of your springs writing the values on them)
had a chat to them about rebuilding/revalving the Tein's that I have, and it is $95 a shock to do.
Who are GC?
Everything is ready to go back into the car as far as the suspension is concerned at the moment, won't do the rebuild of them till later down the track, but I am waiting on a raft of other things before I can put them back in.
I have to do a bumpsteer test as part of the compliance, and that is with the shocks in, but no springs in them, so I have got the car setup for that, which is supposed to be happening tomorrow, still waiting on my stuff that I need to repair the front 6pot calipers from the US along with another set of pads, and that stuff still hasn't shipped yet, so I am guessing another couple of weeks before it gets put on the ground again. Not really sure how it is going to go with 12kg/mm on the front, and 6kg/mm at the rear, whether is going to go from an oversteer monster to the nose wanting to go straigh ahead all the time.
Err, a GC is a good... uh, a good chap...Donovan wrote:Who are GC?
Would have thought that relative mismatch of springs would possibly make it quite understeer-happy?Not really sure how it is going to go with 12kg/mm on the front, and 6kg/mm at the rear, whether is going to go from an oversteer monster to the nose wanting to go straigh ahead all the time.
Oh, ok, change chap for something else I take it.
Well, it was pretty oversteer happy before, so be interesting just how much it throws it the understeer way. I was hoping that the old front ones where about 7kg as it would be closer to what might be a happy medium between the two, but I guess that is not to be.
Just going to be a bit of playing around to try and get the right balance with the right sets of springs to how I like the car to handle on the track.
Yes, it has been corner weighted, have a look at the following post, about 5th or 6th post from the bottom of that page.
http://www.mx5forum.co.nz/viewtopic.php ... &start=100
