Braided lines?
Braided lines?
Are the braided lines legal?
thinkin about changing out all mine as they are now 22 years old!
i was told that only the goodridge ones are legal, but do they need a(nother) cert?
They need to have the outer plastic casing on them,Not bare braided,So WOF guys can see if they are leaking...So i believe,Then don't need cert,
Then again if you have a good WOF guy you see exclusively .....
I've got a set at work myself,Earle's braided,no outer casing,keep tossing up if to or not,I would be getting my WOF to fit them,That way if he fails it them, he put them on in the first place !!.
If you do ,get the lines to suit NB ,Slightly longer,as discussed in other threads
cool.
so the flyin miata ones are $109
and 949 racing $95
goodwin racing have "russel" ones at $115 and goodridge at $144
all in USD for 4 hoses. they all say they are coated dot compliant...is that all i need in terms of compliance? (I.E is dot compliance ok)
and 949 racing $95
Users browsing this forum: No registered users and 82 guests
