by SLYDIT » Sun May 27, 2012 5:24 pm
when i start up SLYDIT, she runs really really bad until its a bit warmed up.
feels like 2.5 cylinders. no smoke or anything.
purs like a kitten after about 2-3 minutes of idling...
any ideas?
i'm thinking maybe ignition related?
by punkoutnz » Sun May 27, 2012 6:35 pm
Could be over fueling when it's cold, or could have a couple of plugs that are on their way out. Mine runs a bit rough when it's cold too, but not to the point of having to do much about it.
by SLYDIT » Sun May 27, 2012 6:40 pm
i can barely back up the drive when its playing up....
it sounds like a bridgeport rotary
i might throw some new plugs at it and see what happens.
by WideOpenThrottle » Sun May 27, 2012 7:28 pm
Had to change the leads on the NB as it was doing a milder version of a rotary.
by SLYDIT » Sun May 27, 2012 8:21 pm
Hmmmmmm
sounds like a good excuse for a coil on plug conversion
dynofiend
by dynofiend » Sun May 27, 2012 8:58 pm
Mine's the same. New plugs helped but it can still be a bitch some mornings. My guess is that the coolant temp sensor/s might need replacing. Wouldnt mind knowing what the values for them are meant to be so I can test my theory.
by brownie » Sun May 27, 2012 9:55 pm
Borrow another coil pack and see what happens,keep it simple at first
Coil pack
Plugs
Leads
by Kieran » Mon May 28, 2012 10:43 am
Sounds like a good excuse for COPs to me
by SLYDIT » Mon May 28, 2012 12:20 pm
I'm not sure my emanage computer can drive coil on plugs. Also I'll have to fit a dwell reducer circuit also.
