What kind of clutch did you get made up(Who, What, Brand, etc) I just got a Carbon Kevlar made up to replace mine.siren676 wrote:Left it at home today as the clutch is on its last legs and I don't trust it. Tried to launch it the other day with a mate in the car and it slipped a heap in 1st gear.
Means i can finally get the paddle clutch installed that I got made up 2 months ago
Got it custom made by autoclutch, sprung center paddle disk with 2000 pound pressure plate.Furai wrote: What kind of clutch did you get made up(Who, What, Brand, etc) I just got a Carbon Kevlar made up to replace mine.
Just asked what he'd recommend if i was taking it drifting and using it as a daily. After he made it up he told me its rated for 300kw
What materials the plate made of and how much did you pay if you dont mind me asking?siren676 wrote:Got it custom made by autoclutch, sprung center paddle disk with 2000 pound pressure plate.Furai wrote: What kind of clutch did you get made up(Who, What, Brand, etc) I just got a Carbon Kevlar made up to replace mine.
i run a similar clutch on my turbo...except a full face disc. if it starts to slip i'll get one like yourssiren676 wrote:Got it custom made by autoclutch, sprung center paddle disk with 2000 pound pressure plate.Furai wrote: What kind of clutch did you get made up(Who, What, Brand, etc) I just got a Carbon Kevlar made up to replace mine.
Just asked what he'd recommend if i was taking it drifting and using it as a daily. After he made it up he told me its rated for 300kw![]()
Cheers..i have made up a plug in connector so the wiring hopefully is all done as well as all the mods to fuel circuit/TPS/AIT sensor wiring etc.halberd wrote:I met a guy the other day who knows his shit about Mazda wiring, he tried talking me into getting a Megasquirt and said he could show me how to wire it in and everything. If you want I can try to find his number and get some info?
Just cant bring myself to plug it all in and going thru the install/download/tune route! till the fuzzies in my head go on holiday!
Slowly getting my NB rear subframe back together.
New wheel bearings, CVs, Energy bushes, stainless lines, new discs. Will be getting a 4.3 torsen in it.
To go in my 91 when I eventually get it back.
By any chance is the 91 you speak of the car you had in your garage that didn't look so original anymore?Euen wrote:Slowly getting my NB rear subframe back together.
No. It is a standard Silverstone 91, 1.6 that got shunted in the back by some little prick in a Trueno/Levin. It is still at the panel beaters but I can't complain too much because it is not costing me much.
Careful with that approach. With no vent, the tank can pressurise in warm/hot weather. Ive heard of it affecting fuel mixtures too. There should still be an opportunity for the tank to vent. It is worth noting that a significant proportion of HCs are produced by unsealed fuel systems venting.Snapfrozen wrote:Space and cleanliness mainly. Looped the 2 lines that it eventually joins to each other and blocked off the intake one.Brainflex wrote:Why remove the charcoal canister?
What did you do with the vent from the tank?
If you loop the lines it vents into the fuel tank with the charcoal canister there that still vents to the fuel tank also doesn't it?
Also the tank will pressurise in warm/hot weather regardless of the charcoal canister being there or not
Ive had no problems with my NB didnt even throw a CEL like Ive heard some peoples do.
The charcoal cannister vents into the intake via a solenoid valve controlled by the ecu. However there is also a vent off the top that ends up in the inside of the front cross menber.
I may be wrong but I think that the the non US (or at least JDM) NBs have a run a fuel return. Certainly the fuel rails on the 2 99 heads that I have, have a return line from the FPR on the fuel rail. Kieran, I would suspect that your 98 would be the same spec.
Users browsing this forum: Google [Bot] and 13 guests
