NA/TURBO/SUPERCHARGE How much did you spend?
Badcat
Post by Badcat » Fri Jan 11, 2013 11:06 pm
Yeah. I like the idea of a supercharger. I've owned a number of turbocharged cars btw. I'm old and busted.
Toolbox
Post by Toolbox » Sat Jan 12, 2013 8:37 am
I once owned a Turbocharged car but now are sold on Supercharged. No going back Now.
Post by SLYDIT » Sat Jan 12, 2013 9:20 am
I just dont see the point. You dont drive the car normally under 2500 rpm so sc has no advantage.
I would be interested to see what turbo cars you owned to put you off them. Things have moved a loooooooong way in turbo manufacture and engine management. A wrx td04 turbo will spool just as fast as sc and make more power.
Post by Furai » Sat Jan 12, 2013 11:29 am
SLYDIT wrote:I just dont see the point. You dont drive the car normally under 2500 rpm so sc has no advantage.
Only cool thing about turbo for me is Anti-Lag systems :lol:
I drive between 1500-2000 when eco driving and just crusing around, but to be honest its below 5000 and around 3500 where I need torque when drifting but Gymkhana is fine as it is.
Thats why I like the NA power curve, it basically just raises the stock curve from 3000RPM up with the best response. I dont need much more power and may not even need any more once I get a 6-speed.
Post by warrior » Sun Jan 20, 2013 2:52 pm
I have a M45 supercharger on my car and i,m fairly sure there is no turbo car that will create boost as low as my car does.
Post by Angreal » Sun Jan 20, 2013 9:04 pm
warrior wrote:I have a M45 supercharger on my car and i,m fairly sure there is no turbo car that will create boost as low as my car does.
Would be good to see how your car compares to mine which should have the mp62 stuck on shortly
Post by warrior » Sun Jan 20, 2013 9:22 pm
I,m guessing you will leave me for dead :oops:
Post by Angreal » Sun Jan 20, 2013 9:37 pm
warrior wrote:I,m guessing you will leave me for dead :oops:
For now I'll be on the smallest pulley just so I can get it certed and on the road again. One day I'll crank it up ... Just it requires more effort than I'm willing to put in as I need it running asap
Post by warrior » Sun Jan 20, 2013 10:01 pm
Same,
I will be getting the bigger pully, larger injectors and intercooler,timing controller then possibly water injection. Looking at the end for around 8-10psi.
Post by Angreal » Sun Jan 20, 2013 10:26 pm
Haha sane idea as me. Start at 5 then eventually get it up to 10-12 and additional injectors as I can't intercool cold side hence more effort than I can be bothered with. Already have the bigger injectors and fuel rail though
Post by Furai » Thu Jan 24, 2013 5:59 pm
Just thought I would post this up, few people linked it to me.
I am not really a fan of 4AGE ones butttt.
http://www.trademe.co.nz/a.aspx?id=555951733
Its a lot cheaper the only thing is it wont be the same power gain as Jenvey ones. But Im sure once I hear them I can live with that. :lol:
Post by SLYDIT » Thu Jan 24, 2013 8:37 pm
when using ITB's go as big as you can. 45mm at a minimum for a 1600. dont forget that in the good ol days of carbs the size of carb was limited by the atomisation of the jets fuel through the venturi. with an injection setup all that is void because the injector is under pressure and atomises the fuel itself.
Post by Furai » Thu Jan 24, 2013 8:46 pm
SLYDIT wrote:when using ITB's go as big as you can. 45mm at a minimum for a 1600. dont forget that in the good ol days of carbs the size of carb was limited by the atomisation of the jets fuel through the venturi. with an injection setup all that is void because the injector is under pressure and atomises the fuel itself.
Maruha uses 40mm for 1.6 and Jenvey recommends 42mm.
I think for top end power that may be the case but torque down low and driveability could be different.
Havent seen a single build 1.6 using 45mm ITBs
Post by Bwarp » Thu Jan 24, 2013 9:41 pm
I've just bought 4age silver top 42mm throttle bodies and trumpets off a mate. Will be getting the T3 adaptor plate from the states when funds allow. I highly doubt an extra 3mm for 45mm's is going to be worth going out of my way to find them, and then port match my adaptor plate.
Watch this space.
Not Doing it to be the fastest guy on the motorway on ramp, so before everyone tells me that turbo/sc is better. I don't care haha. Just want it for noise and a clean/bling engine bay.
YOLO or whatever the kids say these days.
Post by Furai » Thu Jan 24, 2013 9:51 pm
Bwarp wrote:I've just bought 4age silver top 42mm throttle bodies and trumpets off a mate. Will be getting the T3 adaptor plate from the states when funds allow. I highly doubt an extra 3mm for 45mm's is going to be worth going out of my way to find them, and then port match my adaptor plate.
Watch this space.
BOSS BOSS BOSS BOSS BOSS BOSS BOSS BOSS BOSS BOSS BOSS BOSS BOSS BOSS BOSS BOSS BOSS BOSS BOSS BOSS
ITB BUDDIES IT IS
Post by Bwarp » Thu Jan 24, 2013 9:56 pm
I've got your back on the ITB stz bro :wink:
2low2c
Post by 2low2c » Thu Jan 24, 2013 10:27 pm
i have just finished making a set of 45mm ITBs for my 1800 .
45mm are to big for a 1600 for low down power .
bigger is not always best my cylinder head guy has dunn allot of testing on his flow bench and on some race engines they make the ports smaller and achive more hp and torque.
Post by Bwarp » Thu Jan 24, 2013 10:34 pm
2low2c wrote:i have just finished making a set of 45mm ITBs for my 1800 .
Boom. Just what I was looking for. Mine is a 1600. So sounds like the right stuff has conveniently come into my possession
Post by Furai » Fri Jan 25, 2013 8:08 am
Bwarp wrote:I've got your back on the ITB stz bro :wink:
Thought about an ECU?
I just found the company in Japan that Fujiracing was getting ITBS off but I had to ask them a few questions.
The other thing is I emailed Maruha and they said to wait for a little bit as they are working on some big new development...
Post by Kieran » Fri Jan 25, 2013 9:35 am
didnt the fuji racing itb mx5 use 45mm?
Post by Bwarp » Fri Jan 25, 2013 1:42 pm
Yes I have indeed.
Post by Furai » Fri Jan 25, 2013 3:28 pm
They do multiple sizes Kieran,
What ECU you plannign on? Megasquirt?
Post by SLYDIT » Fri Jan 25, 2013 6:13 pm
The whole power/size thing only applies to carbs. Carbs need airflow through the venturi to atomise the fuel correctly. With an injection setup the fuel is atomised by the 40psi fuel pressure. Shit even 1600cc fiat twin cams could run twin 48mm idf carbs.
Post by Furai » Fri Jan 25, 2013 6:55 pm
Have a read of this. Big isnt always better and this explains it well. Also means more coming from Jenvey instead of me
http://www.jenvey.co.uk/jenvey/throttle ... y-dynamics :lol:
Post by Bwarp » Fri Jan 25, 2013 7:20 pm
Furai wrote: What ECU you plannign on? Megasquirt?
Megasquirt. Lol.
Not on the cards at this stage.
Users browsing this forum: Google Adsense [Bot] and 60 guests
