Shameless questions that don't need a whole thread
Post by Junkwhale » Fri Aug 08, 2014 8:24 pm
Timmo wrote:What causes springs to droop/uneven ride height?
I have mazda speed springs on Bilstein shocks. At the back, the ride height is uneven - I can fit about three fingers between the top of the tyre and the guard on the left side, whereas I can fit two fingers on the right side (when I'm not in the car obviously)- I've also just failed my warrant on ride height.
On mine the rubber upper and lower spring seats had perished to almost nothing which I imagine could account for a fingers difference if it's happened on one side only. Numbers 7 and 13 on here:
How much did it fail by/how low was it?
Re: NB hubs
Post by WideOpenThrottle » Sat Aug 09, 2014 9:11 am
Jesse Pinkman wrote:Hi all is it true that NB hubs will fit on an NA and are the NB hubs wider than the NA ones?, so if I wanted to fill the guards without getting new wheels or spacers could I get NB hubs? Cheers
http://www.miata.net/garage/compatibility.html
Jesse Pinkman
hubs
Post by Jesse Pinkman » Sat Aug 09, 2014 6:08 pm
Thank you :)
