by evel » Wed Jun 27, 2012 9:36 pm
Kieran wrote:cause mazda dont make a v8
dont need to, rotary
by Mr. Shine » Thu Jun 28, 2012 11:12 am
evel wrote:dont need to, rotary
Unless you want (despite the added cost of fitting the V8!) reliability
by Furai » Thu Jun 28, 2012 3:14 pm
Mr. Shine wrote:evel wrote:dont need to, rotary
Hey now Rotary engines are reliable and efficient. Thats how they won Lem Mans after all. But they are only reliable and efficient at full throttle, so just drive everywhere flat out.
by evel » Thu Jun 28, 2012 7:09 pm
by Bwarp » Mon Jul 02, 2012 7:42 pm
Kieran wrote:
The 2001-2005 Miata engine is VVT so same thing
Doesnt the VVT in a Mazda engine only adjust timing?
VTEC adjusts valve lift and timing as far as im aware.
Fairly different styz.
by Bwarp » Mon Jul 02, 2012 7:43 pm
Also - welcome along Jarred.
I was at last NZH NIMM in Taupo. Would i have met you there? I'm sure I did.
by Kieran » Tue Jul 03, 2012 10:29 am
Its a seperate cam profile and exactly the same there are some slight variances between manufacturers
The Major difference between honda VTEC and every other car manufacturers VVTi is that Honda made the first production model with it
by Euen » Tue Jul 03, 2012 10:52 am
The Mazda VVT on the BP only adjusts the timing of the inlet cam. There is no change to lift or duration.
by Kieran » Tue Jul 03, 2012 10:54 am
really i was under the understanding that it is a seperate cam lobe?
Just did a little research my mistake but still I would prefer that over VTEC
by Snapfrozen » Tue Jul 03, 2012 11:18 am
Love VTEC. Not many 1.6L cars can make 140wkw with barely any headwork
by Kieran » Tue Jul 03, 2012 11:22 am
Yeah I respect that but still...
My mate has an civic hatch same as the one above 1.5L SOHC with a SC14 Supercharger he blew his engine on the dyno at 6PSI haha
by Snapfrozen » Tue Jul 03, 2012 2:26 pm
Kieran wrote:Yeah I respect that but still...
The D series SOHC engines are VERY hard to kill, musta been awfully unhealthy. Other thing that might killed it is that Honda engines spin the opposite way to most supercharges so did he factor that in?
by Kieran » Tue Jul 03, 2012 2:35 pm
yeah hes a mechanic so i trust it was healthy and he did factor that in cause its running fine on the new engine now just bad luck on the last one I think cause it threw a rod and pieces went flying all over the workshop it was quite funny actually
