you need at least a 225 on an 8" rim if you want a cert
unless you can get documentation from the tyre manufacturer to say that its recomended for the rim width
according to the LVVTA schedual a 195 45 15 will only be certified on a 7.5" rim
New Wheels
LVV certification is not required provided that the wheels:
-are a known and reputable brand non-OE item; and
-would be considered an appropriate fitment for the vehicle type by the wheel manufacturer; and
-are not modified; and
-spacers or adapters are not fitted.
From this document here.
Otherwise, however, LVV certification is required, and if you decide to change your wheels to a different width after certification you'll need to get it re-certified with the new wheels.
