Project: Jenny craigs
Post by marcellarius » Mon Jul 28, 2014 11:23 am
chris wrote:No "real" updates.
I have picked up some bilsteins, that will be getting sent to Autolign and sorted out with a 5/7kg spring
7kg in front I hope?
Post by chris » Mon Jul 28, 2014 1:10 pm
No...? In the rear....?
Of course in the front :P My bad for putting them the wrong way around.
Post by warrior » Mon Jul 28, 2014 2:13 pm
When the next track day chris? Keen to come along for a look again.
Post by chris » Mon Jul 28, 2014 3:03 pm
Next one is this Sunday!
Pop along, I will give you a ride in the boxster :)
And if your son wants a ride, he's more than welcome to join!
We have helmets to spare :)
Post by warrior » Mon Jul 28, 2014 3:13 pm
Thanks mate............
Post by chris » Thu Aug 07, 2014 8:59 am
Long time no update, because I have lacked motivation.
Last night I removed the steering column, why? Two reasons. First, I have a manual rack going in shortly. Second, I decided to see if I can either A) make a new one or B) modify this one to be better suited to my seating position.
It doesn't seem like it will be too difficult.
I will post pictures and what not tonight, but yay for updates!
built4speed
Post by built4speed » Thu Aug 07, 2014 12:14 pm
De power your current rack and use that otherwise you get a higher lock to lock ratio which is shit for the track.
Post by chris » Thu Aug 07, 2014 12:34 pm
Already depowered it.
Had a manual rack in my old mx, much more preferable IMO.
built4speed
Post by built4speed » Thu Aug 07, 2014 2:00 pm
chris wrote:Already depowered it.
Have you removed the piston/seal in the rack? Welded up the slop in the pinion valve setup?
Mine felt so much better after removing the slop.
Post by chris » Thu Aug 07, 2014 2:15 pm
Nope - but still just going to go straight to a manual rack.
Looking forward to this weekend, hopefully going to be able to borrow someones welder and get some cool work done to the car!
Post by 4A-GE » Thu Aug 07, 2014 7:54 pm
Excluding the weld and piston/seal, what else goes into depowering a rack?
Is it particularly difficult to reverse?
Post by BRM » Thu Aug 07, 2014 11:41 pm
built4speed wrote:De power your current rack and use that otherwise you get a higher lock to lock ratio which is shit for the track.
You don't need much lock for track.
built4speed
Post by built4speed » Fri Aug 08, 2014 6:23 am
You don't gain any lock, it's the amount of steering input you have to apply to get around a corner is more with a manual rack.
Post by chris » Mon Aug 11, 2014 10:11 am
Tbh, you can argue this matter all you like, I am going to a manual rack purely because I prefer the steering feel you get from it.
Also - purchased a welder this weekend, went shopping for a tool bag, came back with a welder
#logic?!
But, I have had a shit tonne of practice with it yesterday, the welds are slowly looking better, so tonight I will be attacking the seat mount to get it as low as possible.
Post by marcellarius » Mon Aug 11, 2014 1:06 pm
A manual rack is probably much easier if you want to keep the car street legal too. From what I've read, the LVVTA seem to want you to get a steering specialist to depower the rack
Post by Timmo » Mon Aug 11, 2014 6:23 pm
Just so's you know, modification of seating/rails etc will require certing.
Post by chris » Tue Aug 12, 2014 9:19 am
Yup Yup - aware of that, they are already modified :P
Just not low enough for me..
Post by Angreal » Tue Aug 12, 2014 8:50 pm
Just putting it out there but when it comes to structural welds you should get someone who can weld to do it... Looking pretty and being a proper weld are different things.
Double post but I guess it's kinda an important thing to note ;-)
Post by chris » Wed Sep 03, 2014 10:04 am
Been slow as hell updating this.
Motivation is kind of lacking at the moment.
Mainly because I just had to drop $620 on new tires for the daily >.<
However, Seat mounts are welded to the floor.
Steering rack has some 1/2 inch spacers to lower it a tad.
I have hours and hours of work ahead of me to install all new bushings.
Hopefully I'll get some motivation this week to start back onto the car!
Post by SkilletKid » Thu Sep 04, 2014 1:21 am
Oh bushings.... yea....
I am in so much pain right now.
(in the process of doing mine =P)
Post by warrior » Thu Sep 04, 2014 10:03 am
Mine are sitting on the bench....AUTOLINE will take out the old bushings and put in the new ones for a small fee.
That's what I,m going to do.
