MX5 High HP Build Thread
Hi all,
I have always been a Die hard Mazda Fan and now have decided to start a new project. Over the last year I have been picking up bits and bobs to make a top-spec BP 1800 Turbo.
The Cylinder head is finished complete with:
-272 Cam shafts
-Solid Lifters
-Kelford Valve springs and Retainers
-Corksport Cam gears
-Custom fuel rail
-Honda K20A Coil on plug conversion
-ARP Head Studs
-Custom Intake manifold using Toyota 4AGE Black top throttle bodies (Being made in Perth by ActionDan customs)
-Custom coolant re-route kit from mx5plus.com.au
The Block (BPT) is still under construction with:
-Eagle Conrods
-Wiseco Forged pistons
-ACL Race series bearings all around
-Chromolly 4kg Flywheel
-Clutch industries RPM 4puk sprung centre
-Boundary Engineering Oil pump (Still to come)
-ATI crank dampener (Still to come)
As for Turbo wise I picked up a Turbonetics T3/4 60 Trim with V band exhaust Housing from Barry at MRP.
All of this to go into this little blue NA6 I recently purchased which in time I will convert to a NA8.
The NA6 Had a lot of rust around the boot and door sils among many other areas in the car so out came the rust down went the rust killer, primer and then topped it off with the original MX5 blue.
This is what I have done so far much more to come!
-272 Cam shafts
-Solid Lifters
-Custom fuel rail
-ARP Head Studs
-Eagle Conrods
Yep thats the Idea, Chris Burrett the owner of AL4SPN (orange BFMR) in NZPC managed a great 296 wKW with the exhaust cam swap and ITBs so I hoping to demolish 300KW finger crossedFurai wrote:No problem, looks awesome by the way the engine is a masterpiece of engineering!
ITBs and Turbo? Should be putting out some good figures!
Yep sure is! Has had a bit for TLC already doesn't smell like a caucus anymore either! Was a great buy and was in walking distance from where I live so super chuffed with that! Its going in for some more panel and paint in the next month for a final tidy up but plan to keep it blue.punkoutnz wrote:That's Darryl's old MX5. Has polished up really nice! Pretty mint looking project.
Project 10 second MX5
a quick fiddle with the drag time calculators reckons you'll need 320+ hp , which is not unheard of ! good luck :]
Re: Project 10 second MX5
Cheersjif wrote:a quick fiddle with the drag time calculators reckons you'll need 320+ hp , which is not unheard of ! good luck :]
Somewhere on the web I have seen an 1800 NA drag car that had around 600hp. Not too sure what times it was doing though.
There is this one but that runs a rotary.
http://www.youtube.com/watch?v=Iv6NJFlzP8U
UPDATE: Found it.
It does 8 second quarters - at 24 pounds of boost!
http://www.metacafe.com/watch/1273231/8 ... drag_race/
UPDATE: Found it.
Both very cool! The NB cooler again, I don't want to resort to a rotor, piston should be able to do it. Getting the power down will be the big question.Growler wrote:Somewhere on the web I have seen an 1800 NA drag car that had around 600hp. Not too sure what times it was doing though.
UPDATE: Found it.
You mean this one? Its an NA MX5 with an RB26 Skyline engine putting out 900hp.SLYDIT wrote:ive also seen a BRG(or was it black?) NA drag car somewhere...i'll dig it out of the interweb for you
http://www.youtube.com/watch?feature=en ... t4qTQ&NR=1
and here losing it but saving it?
http://www.youtube.com/watch?v=Bw_4qae2zWI
Yeah I saw these both earlier in the year. Going to try get the 10sec slip with all stock trim and the Mazda BPT with a few tweaks (Despite loving the RB26)Growler wrote:You mean this one? Its an NA MX5 with an RB26 Skyline engine putting out 900hp.SLYDIT wrote:ive also seen a BRG(or was it black?) NA drag car somewhere...i'll dig it out of the interweb for you
I know him well if you want to get in contact with himREDBEN wrote:Yep thats the Idea, Chris Burrett the owner of AL4SPN (orange BFMR) in NZPC managed a great 296 wKW with the exhaust cam swap and ITBs so I hoping to demolish 300KW finger crossedFurai wrote:No problem, looks awesome by the way the engine is a masterpiece of engineering!
Haha Cheers I got in contact with Chris as soon as his car came out in NZPC He's been a huge help with my build especially with the K20A Coil on plug set up. He's a pretty helpful guy. People like that hard to come by these days.Born_disturbed wrote:I know him well if you want to get in contact with himREDBEN wrote:Yep thats the Idea, Chris Burrett the owner of AL4SPN (orange BFMR) in NZPC managed a great 296 wKW with the exhaust cam swap and ITBs so I hoping to demolish 300KW finger crossedFurai wrote:No problem, looks awesome by the way the engine is a masterpiece of engineering!
Ha yeah Chris is definitely a GC. Which remind ms i need to ask him about that COP setupREDBEN wrote:Haha Cheers I got in contact with Chris as soon as his car came out in NZPC He's been a huge help with my build especially with the K20A Coil on plug set up. He's a pretty helpful guy. People like that hard to come by these days.
I do have all the info on the conversion including the drawings on solid works which I can get laser cut cost me $35 for the plate to be cut out of 3mm Stainless, I can get the Coils from Repco not cheap but brand new and then you need the fitting bushes to be made up I made them on the lathe at work could make you a set if youd like? Then for plugs you just get them from Strong for Honda. PM if you need more details.Born_disturbed wrote:Ha yeah Chris is definitely a GC. Which remind ms i need to ask him about that COP setupREDBEN wrote:Haha Cheers I got in contact with Chris as soon as his car came out in NZPC He's been a huge help with my build especially with the K20A Coil on plug set up. He's a pretty helpful guy. People like that hard to come by these days.
Users browsing this forum: Bing [Bot] and 103 guests
