leaking mx5 ahhh
patrick malone
leaking mx5 ahhh
Post by patrick malone » Wed Jun 23, 2004 12:19 pm
my mx5 seems got its head thats it a submarine at
present , the carpet in front of the drivers seat and
behind get saoked when it rains.
also water seems to drain in front the right rear
wheel l assumed it was a drain for the roof.
as it seem to have hose there but as l dont have
maunuall or much knowledge on mx5,s
any help whould be apprecitaed
thanks
patrick malone
Chic Lynch
leaking mx5 ahhh
Post by Chic Lynch » Wed Jun 23, 2004 6:50 pm
Patrick,
There IS a drain for the roof just in front of the rear wheels. If you
look behind the seat belt towers with your roof up, you will see a
plastic 'funnel'. The water from the roof goes along the rain rail and
down this 'funnel'. It should then come out under the car near the rear
wheels.
This drain gets blocked quite easily and I usually clean mine out by
inserting a piece of garden hose down the 'funnel' and pushing until it
comes out the bottom (usually accompanied by mud and leaves).
My theory is that, when this drain gets blocked, water overflows into the
sill. The sills also have drains that usually get blocked. These drains
are just gaps in the seams that run the length of the car. The drains are
just at the jacking points. I clear these by inserting a screwdriver and
pushing up and wiggling it until the water starts coming out.
When all the drains are blocked, I think water overflows into the foot
well. We had 10 cms of water in there once. Incidentally the foot wells
also have drains which are plugged by a rubber stopper. If you need to
drain water from that area, simply pull back the carpet (from the sides)
and pull out the plug.
Hope this helps
Chic
Chic & Morven, us@lynchz.com on 23/06/2004
thanks
patrick malone
patrick malone
leaking mx5 ahhh
Post by patrick malone » Thu Jun 24, 2004 11:10 am
--- Chic Lynch <mx5list@lynchz.com> wrote:
Patrick,
rear wheels. If you look behind the seat belt towers
Hope this helps
Chic
thanks very much is very helpful, yes suspected might
be the case.
Return to “2004”
