1990 NA 13B ENGINE SWAP . Progress Pic
Any one on the forum done this conversion ....
dont think so, but you might wanna look up member nfs13b at aus-cartalk.com.au
Don at autoway services has done this conversion.
off the top of my head it required:
-New front engine subframe welded to the cross member.
gearbox was frankensteined with a mx5 rear and rx front housings.
-Firewall had some massaging to clear the engine.(crankshaft center sits higher in a rotary)
-low pressure fuel regulator for the carb
He had it for sale . maybe it still is?
MX5 13B
I have a 1989 NA MX5. Will be building a 13B bridgeport engine.
The gearbox i am using is out of a 1994 FD RX7 with FC bellhousing.
I am using TII diff and half shaft. Will be running a 4 barrel nikki carburetor
and will go injection and turbo late next year.
Nice.
What sort of diff are you using?
How much HP do you expect?
Anthony
Anthony
new project NB 13B Rotary
i have a new rotary project. Its a NB that i have bought from MX5 Mart.
Users browsing this forum: No registered users and 92 guests
