Clutch Cover
Clutch Cover
What does the clutch cover do other than cover the clutch? Is it worth replacing at the same time as a clutch?
Re: Clutch Cover
Yes do the lot at once whiles your in there.Angreal wrote:What does the clutch cover do other than cover the clutch? Is it worth replacing at the same time as a clutch?
So is the clutch cover the bit that applies the pressure? I always thought it was the clutch itself... Guess it's time to do some reading up on how it all workssiren676 wrote:Yes its a good idea to replace it at the same time as the clutch. Maybe consider going to a slightly higher pressure one at the same time since your planning on supercharging it
This is the website which taught me how they work when i was doing automotive at school
http://auto.howstuffworks.com/clutch.htm
i run a 1800 flywheel and stock 1800 clutch plate but with a 1 ton cover. Drives like stock but handles the power great.
http://www.youtube.com/watch?v=qd-XHCTS0iY
Sweet. Sold on a replacement cover and throwout bearing I guessSLYDIT wrote:i run a 1800 flywheel and stock 1800 clutch plate but with a 1 ton cover. Drives like stock but handles the power great.
Might aswell do the spigot bearing tooAngreal wrote:Sweet. Sold on a replacement cover and throwout bearing I guessSLYDIT wrote:i run a 1800 flywheel and stock 1800 clutch plate but with a 1 ton cover. Drives like stock but handles the power great.
