Issues... urgent help appreciated, trackday on thursday!
So I got the turbobeasty out on track on monday finally, however the turbo came loose on the exhaust manifold mid-session and by the time I noticed it the hot air had melted a few hoses etc - PCV breather and the wee ones to the boost controller. It also melted a dirty great hole in the cambelt cover, so it was pretty hot under there. Water temp was still fairly stable though in mid-90s, which seemed ok to me?
I've replaced/rerouted the hoses and my mechanic re-studded the manifold today (he had to drill out all 4 of them), [-]but the boost seems to be misbehaving - instead of being responsive low down and pulling the 12psi it was set to before the incident, its lagging and then jumping up to 16... I didn't keep my foot down to see if it would go higher.
The hoses to the boost control are a bit longer now, but I'm guessing its one of two things -
a) I've plumbed the boost tap in the wrong way round - would this have that effect?
b) The (manual) boost control has been stuffed by the heat?
I haven't tried turning it up or down yet as I assumed it would be the same, but I might try that soon in case its just that.[/-]
The other issue is that the brakes went really soft/long in the pedal - I thought it was just old fluid but after bleeding they're still soft, I've just been checking the rear caliper adjustment so might bleed again after that, any other ideas? I can't see any damaged or bulging hoses, maybe the master cylinder is poked? It looks good and clean from the outside but you never know.
On the bright side it was hustling around Teretonga really nicely for the 20 minutes of tracktime I got before discovering problems... but if I can't get it sorted tomorrow then I'm taking the Legacy up for Levels and Ruapuna instead!
Boost was sorted by adusting boost controlller, I guess mechanic had just wound it right open or something. Now holding a steady 12psi.
Brakes still baaaad though! By which I mean you can just get it to lock a wheel in the wet, but the pedal is on the floor
and only one day to get them fixed or I will be trackdaying 1500kg of Subaru wagon!
I would be checking the state of the pads, you may have overheated them if they are not road/track rated as some road pads only last 3 laps (however most also are then ok after they cool).
If you are doing 20 min sessions I would make sure you have good road / track pads
I would also be replacing the brake fluid for sure.
On a side note you might want to look at putting in an approved roll bar if you plan to track the car.
If vacuum to the servo is lost the pedal will go harder not softer as there is no servo assistance.
I assume you have checked for fluid leaks. If there are no leaks I would tend to suspect the master cylinder.
Were you getting good fluid pressure when you bled the system. Any noticeable variation in fluid pressure between the wheels?
Even with the increased pedal travel, are you getting any braking on all 4 wheels.
Have you actually checked how much material is left on the pads? Worn pads can result in a longer pedal.
Interestingly the pedal was a lot firmer this morning than last night, maybe there was still some air trapped that hadn't bled out properly that worked itself out as it cooled overnight. Got mechanic to give it a quick bleed for me this morning too (while I'm stuck at work) to make sure, its still not amazing but much better than it was.
I'd checked for leaks and bulging hoses but couldn't see anything.
Pads had plenty of meat when I checked last week and surely a 15-20 minute track session wouldn't eat them that fast - but they're nothing great, so I have some Bendix ultimates on the way to replace the front ones.
Gasket blew out again at Levels, looks like mechanic that fixed it on tues used studs that were a bit too short which didn't help! Had the time to fix it myself with better studs and gasket this time. If it goes again (Ruapuna tomorrow so I'll find out soon enough!) I'll have to find a better solution - there is talk of inconel studs solving the problem on pistonheads and miata.net, which I expect are very expensive! Sounds like a brace from downpipe to bellhousing makes a big difference as well.
Interestingly the soft brake pedal seems directly related to the exhaust leak as it was fine until that happened, and went soft immediately afterward.
Much better feeling with the new pads in now.
Turbo
Argggghhhh! what have you been doing to the beast??
Yes I would tak weld the studs to the manifold, I also think the brake lines got a little "hot under the collar" when the exhaust gases where let loose
Inconel bolts sound very expensive, but probably cheaper than Gamma Ti ones
Use Nordlok washers on the stud and nut assemblies too.
lol
You could also spend that sort of money on a Psychiatrist! ( which will no doubt, go towards his/her car)
lol
Haha, I wish! But I am sure I will spend alot more money on it!sprsta wrote:so you want it back then jim?
Dangerousssss
