If anyone has any information on these ECU's I'd be greatful.
The T25G has sockets for water cooling, but they are nt installed. I have spoken to a couple of people who "do know" turbos, and they said if I'm not on a race track they wouldn't bother and it doesn't really help run down times at all. Plus it doesn't make it much cooler under the bonnet.
This was more of an issue with older oils due to their coking (sp?) problems, not a problem with modern synthetics.
Any thoughts?
Benefits,
If I plumb into the heater pipe, then the heater would warm up quicker on cold days
A very slight air inlet temp decrease may occur.
Disadvantages,
Higher load on the radiator.
Mildly cooler Turbo.
Has anyone got a radiator from an NB auto they don't happen to be using? As these are about a 1/3 thicker than stock.
