Elden Ring Incantations Tier List 2025: The Best and Worst Spells for Every Build
BraidSlate
Post by BraidSlate » Wed Jul 23, 2025 3:01 pm
Elden Ring continues to captivate players with its ever-expanding world and deep gameplay mechanics. One of the standout features of the game is the use of incantations, powerful magic spells that allow players to buff themselves, deal devastating elemental damage, or even heal. With the 2025 updates and tweaks, some incantations have been buffed, while others have fallen out of favor. In this Elden Ring Incantations Tier List 2025, we’ll break down the top spells you should prioritize, the ones worth skipping, and why they matter to your builds.
The S-Tier: Incantations You Can't Miss
These incantations are the crème de la crème of Elden Ring magic, offering high utility, strong damage, or both. If you’re building a character around incantations, these should be your go-to choices.
1. Flame, Grant Me Strength
This incantation remains a fan favorite, offering a powerful boost to physical damage output. Whether you’re a Faith-heavy build or simply seeking to buff your weapon’s potential, this spell is a must-have. Its effectiveness in both PvE and PvP scenarios makes it a staple.
2. Dragonfire
For players looking to deal massive damage, Dragonfire is a must-use. This fiery breath weapon can clear entire groups of enemies in a matter of seconds. The high FP cost is a drawback, but the raw power it brings to the table compensates for it.
3. Blessed Light
Perfect for hybrid builds, Blessed Light provides continuous healing over time. This can make a huge difference in longer fights or tough bosses, letting you focus on offense without constantly worrying about healing.
The A-Tier: Solid Choices That Deliver
If you’re looking for reliable incantations that fit into many different builds, the A-tier spells are excellent choices. They may not be as universally game-changing as S-tier spells, but they will serve you well throughout your journey.
1. Lightning Spear
A classic in the Elden Ring Incantations Tier List 2025, Lightning Spear offers excellent range and quick casting speed, making it perfect for poking at enemies from a distance. While not as powerful as the S-tier picks, it remains versatile and a solid choice for many builds.
2. Raging Flame
Raging Flame provides high burst damage, especially in boss fights. The sheer ferocity of this spell makes it great for fast-paced encounters, but its narrow range and charging time make it less effective in more controlled settings.
3. Golden Vow
For those seeking to improve survivability and damage, Golden Vow boosts your attack and defense. While it’s primarily a buffing incantation, its overall utility in almost any build makes it a strong choice.
The B-Tier: Worth Considering for Specific Builds
While these incantations aren’t the best options across the board, they hold value for particular builds or playstyles. Consider these if you're experimenting with different setups or need something niche.
1. Black Flame
The Black Flame incantation does impressive damage over time, especially against bosses with high HP. However, its casting time and FP cost might leave you vulnerable if you're not careful. While it can devastate enemies in the right hands, it’s not as universally useful as other spells.
2. Flame of Frenzy
This incantation works well in PvP situations, where its frenzy effect can disrupt enemy builds. The ability to trigger madness in other players is a powerful tool, though its application in PvE is limited.
3. Beast Roar
For Strength-based builds or players focused on crowd control, Beast Roar can be a handy tool. It has a decent range, and the stagger effect can buy you some much-needed breathing room, especially when facing multiple enemies at once.
The C-Tier: Good for Fun, But Not Ideal for Competitive Play
In this tier, you’ll find incantations that might be fun to experiment with but don’t hold up well in most situations. If you’re looking to min-max your character or engage in tougher fights, these spells may fall short.
1. Catch Flame
Despite its low FP cost and quick casting time, Catch Flame simply doesn’t provide enough damage or utility to be useful in the later stages of the game. It’s better suited for early-game or novelty builds, but you’ll quickly outgrow it as the game progresses.
2. Ice Storm
The Ice Storm incantation does decent AOE damage but lacks the punch to make it truly impactful. Its slow cast time and relatively weak damage output make it a poor choice for the endgame.
The D-Tier: Avoid Unless You’re Feeling Experimental
At the bottom of the Elden Ring Incantations Tier List 2025, these incantations are generally outclassed by others in terms of damage, utility, or flexibility. While they have niche uses, you’ll likely find yourself wanting better spells.
1. Smoldering Wall
While it sounds exciting, Smoldering Wall is an extremely situational spell that isn’t worth the investment for most builds. Its range is limited, and its damage isn’t enough to make it a valuable asset in tougher fights.
2. Flame of the Redmanes
While this incantation does decent area-of-effect damage, it requires very precise positioning to land successfully, making it awkward and impractical in many situations. Unless you’re looking for a challenge, it’s best left off your hotbar.
Conclusion: Tailor Your Incantations to Your Playstyle
In the vast world of Elden Ring, the power of incantations cannot be overstated. Whether you’re looking to rain down destruction on your enemies with fiery wrath, heal your team in the middle of a grueling battle, or enhance your combat prowess with buffs, the right spell can make all the difference. However, with the Elden Ring Incantations Tier List 2025 in mind, it’s clear that not all incantations are created equal.
Focus on finding the right balance between offense and defense, experimenting with various builds, and always keeping an eye on updates, as the balance of spells can shift with patches and new content. With the right incantations, you’ll become a force to be reckoned with in the Lands Between.
Users browsing this forum: Google [Bot] and 54 guests
