2/ Don't leave your wallet in the boot
Seriously, if you ever put your keys in the boot of your NZ model, and then the bootlid shuts, your stuck - because this model doesn't have an internal boot release latch.
To unlock the boot, follow the following procedure :
1/ remove the number plate.
2/ draw an imaginary line between the lock and the boot latch.
3/ drill a 1 inch (25mm) hole mid way along this line.
DO NOT DRILL TOO DEEPLY
4/ with some needle-nosed pliers, gently reach in and grasp the wire that connects the lock and boot latch, and gently tweak it until the boot pops open.
5/ Remove your keys and vow never to let this happen again.
6/ In case it happens again, fit a rubber grommet in the hole before you replace your number plate.
This happened to me one New Years Day on the Rawene Ferry, many thanks to the Rawene Garage who provided this solution!
