Auto trans engines
Auto trans engines
Hi all
Although not a club memeber I have been following the forum for a few months. I am currently planning a project car based on MX5 mechanicals and have a query regarding the engines used with automatic transmissions.
I understand that the "auto" engines are slightly "detuned" but have not seen any info on what has been done to reduce the power. Can anyone please tell me how this has been achieved.
Auto trans engines
As far as I have been able to find out, the auto engine has different
pistons (deeper dish in the top of the piston) to reduce the compression
slightly so lowering the revs at which peak torque is produced. This is to
match the engine characteristics better to the torque sapping auto trans.
Grant
Grant
Auto trans engines
Grant
Grant
Auto trans engines
hey euen.
my first mx5 was an auto.
if i remember correctly, the cams and/or cam timing is also different on the
auto motor.
what are you building by the way?
ken
From jifjif@gmail.com Fri Apr 27 17:15:00 2007
h=received:message-id
b=UZF4ZqshXzcfFG2RMglhCy+d4i2d5FgxKZKWAK88J6xgRqUjd5xmA23URkqku+JMpsEiPbDrq24uq98gnY5DskG1zotQHrXnK3kPVRZWdGdizTonvYRKaK1+b+/KsR6Cgeh1yj4k/EYn9dfzHUWewVycOnBZpDwcjfzZz6CqW3c=
Date: Thu, 20 Jan 2005 11:41:28 +1300
Subject: Re: Auto trans engines
In-Reply-To: <20050119212859.CAQM16943.pop2-rme.xtra.co.nz@210.86.15.137>
Mime-Version: 1.0
References: <20050119212859.CAQM16943.pop2-rme.xtra.co.nz@210.86.15.137>
Message-ID: <TzKh6B.A.8o.RdYMGB@L733>
only the 1600 auto engine is like this, IIRC the 1800 autos are the
same as the manual version.
... smells like forced induction to me!
On Thu, 20 Jan 2005 10:28:59 +1300, euen.burke@xtra.co.nz
auto motor.
ken
months. I am currently planning a project car based on MX5 mechanicals andFrom: <euen.burke@xtra.co.nz>
Date: 2005/01/20 Thu AM 10:28:59 GMT+13:00
To: <mx5list@mx5club.org.nz>
Subject: Auto trans engines
Hi all
seen any info on what has been done to reduce the power. Can anyoneI understand that the "auto" engines are slightly "detuned" but have not
ken newellThanks
Mime-Version: 1.0
Auto trans engines
hey euen.
auto motor.
ken
Mime-Version: 1.0
auto motor.
ken
Hi all
ken newellThanks
Mime-Version: 1.0
Auto trans engines
Hi Euen,
Is it an MG replica you're building or something else?
Simon
Quoting "euen.burke@xtra.co.nz" <euen.burke@xtra.co.nz>:
manuals are 9.5:1. You would need a new set of pistons to remedy this.From memory on the 1600's the auto engines are 9.0:1 compression ratio and the
Simon
Auto trans engines
Hi Euen,
Simon
Simon
Auto trans engines
Thanks Grant, Ken, Simon and Jeff.
Sorry Jeff, no forced induction planned for this project. Planning for 1800 5 speed with maybe a few little tweaks.
Simon, you got it. For those who haven't seen it, check out http://www.sportscars.net.nz/
