CATs go bad after 2-3years anyway, so we all should change them every
coupla years if you want the gains (nature wise)from the CAT. The
thing with the cat by-pass is that there is no longer the restriction
of the material in the cat. This results in a better flow of the
exhaust fumes and so your engine loses less power by pushing the
fumes through CAT, result more horsepower (2bhp).
WiM
Quoting zorruno <
admin@mx5forum.co.nz> on Fri, 25 Nov 2005
11:56:28 +1300:
on 24/11/2005 9:17 p.m. David wrote:
Removing catalytic converter's rates up with
neons, fluffy dice and sticker
horsepower.
Sure you get the slightest improvement, but
there are usually VERY harsh
fines if you get caught. IMHO it's just not
worth it.
Sorry, are we talking about NZ still? Unless
something has changed in
the last few months (?), it is not illegal to
remove a Catalytic
converter. It likely is in other countries, but
please rem
ember this is
a NZ focussed list, so a bit of clarification is
always helpful. I'm
not sure of the legality of fluffy dice however
(it may be different
with various Council bylaws).
Whether it is sensible however is up to the
individual, I doubt the
gains are much (I've seen dyno figures of 2-3hp
touted around), and
there are issues of change in exhaust tone, oxygen
sensors in later
models, killing trees etc.
A couple of other clarifications, Eunos models (at
least up to 94, and I
assume 97 and probably later) do not have a
dashboard check engine
light. So if you don't reconnect an oxygen sensor
at a Cat, you
probably won't notice unless you connect up an ODB
checker (an expensive
LED) to the ECU connector. US models flash a big
light on the dash to
say 'you've done something bad - get me to a
mechanic'.
There is no reason why you can't just reconnect
the oxygen sensor back
into a straight pipe, or small mu
ffler - some of
them come already
threaded.
Personally, I like trees, reduced carcinogens and
not spending lots of
money on small power gains so my cat stays...
H
WiM
www.mx5ireland.com
