part needed!!
Neil Leathley
part needed!!
Post by Neil Leathley » Fri Jan 05, 2001 7:56 pm
WANTED URGENTLY
Second-hand or cheap new- left hand headlight motor for a poor old 1990 model
that has a winking problem.
Any help, suggestions gratefully accepted
Neil Leathley
part needed!!
Post by zorruno » Mon Jan 08, 2001 7:45 am
I've never heard of a winking problem before - I thought that was only an
mr2 specific problem?! :)
are you sure it can't be fixed without replacing the motor? what exactly
are the symptoms?
Neil Leathley
part needed!!
Post by Neil Leathley » Mon Jan 08, 2001 9:29 am
Hi zorruno
Thanks for your interest. The symptoms are as follows. When I turn the
lights off the left hand light continues to flick up and down. Of ten the
only way I could stop it was to flip the headlights up, as if I was going to
clean them. But just recently, even that won't stop it and I have had to
disconnect it. It is most disconcerting driving along a crowded motorway
and your light is winking at all and sundry.
I live in Whangarei and took it to an auto-electrician, who said the motor
was fine, and thought it was something in the sealed electronic controls
which sit on the motor, hence the need for a whole new motor at $450 plus
G.S.T.!
Do you have any ideas?
Neil Leathley
Return to “2001”
