Suspension bushes
Mathew
Suspension bushes
Post by Mathew » Fri Nov 15, 2002 10:18 am
Hi Gary.Did you just replace them with factory bushes, or did you source aftermarket ones.
M@
Gary Morrison
Suspension bushes
Post by Gary Morrison » Fri Nov 15, 2002 5:41 pm
Hi Matthew,
I used the factory ones. Cost for the rear set was about $450. As the suspension was in bits it wasn't too much of a job, except that I had the old bushes pressed out, the suspension parts stripped and powder coated, and then the new bushes pressed in. That all cost about $100. There is a set from Flyin Miata in the USA, Powerflex I think, and they seem to work out about the same or slightly less. They are a urethane set I think, and supposedly should last forever.
Gary
M@
Return to “2002”
Users browsing this forum: No registered users and 63 guests
