I'm now the proud owner of a Cusco 2 way RS version LSD. And it needs to be fitted....
I thought I can do this myself or any grease monkey will do…. But NO! a couple of the gear heads at work said "STOP" this is a job for a skilled professional, and do not go to a gear and transmission company.
The surfaces have to be blued and if it's set up less than 100% correctly then it's noise or excessive wear. Anyone have any recommendations. Some of the drift forums mention Diff Spec in Manukau (nice to have someone closer) and Steelie Gears in Otahuhu.
Thoughts all?
Gazda
I'm so pleased I pasted all that into Word for a spell check first
Who in Auckland can install my LSD (Properly)
Gazda in the white HOT Mazda
who ever you use, i suggest getting some info off the net about correctly setting up MX5 diffs with any special requirements needed and even a "how to " on how to PROPERLY disconnect the diff assembly from the Power plant frame. It may be telling the diff guy to suck eggs but its nice to leave them that info "just in case" they cant find the info on corrrect setup such as back lash etc...time for some googling i think
