film on soft top plastic window
My top has a milky coloured film 50mm wide around the bottom exterior section of the window. The car is not able to be garaged and is outside at all times and 800 metres or so from the sea. The area of the window not affected cleans up okay with Meguiar's clear plastic cleaner. Any ideas to remove this film without damaging the plastic would be very much appreciated.
film - plastic window
Thanks Zorruno, was hoping there may have been some way of cleaning it up. The film is more milky than brown, but will probably go brown. The window was replaced approx 4 years ago, perhaps more frequent cleaning may have prevented this present condition.
