Post by WideOpenThrottle » Thu May 08, 2014 10:38 am
Hi slydit...this is where you are partly right!?
Notes:
On Miatas without a return line (99+), the high flow pumps flow more fuel at any given pressure level than is needed for a stock vehicle. They tend to overload the OEM FPR and cause the system to run rich even in vacuum. Tuning is required with the high pressure pumps due to increased fuel pressure.
Post by SLYDIT » Thu May 08, 2014 7:27 pm
the NB definitly need a better pump as they lean out at high rpmb ecause of the higher pressure/flow requirements. the NA6 FPR cannot cope with a 255 walbro. its well documented.
Post by WideOpenThrottle » Fri May 09, 2014 12:09 pm
Just been for a couple of hours drive with the Walbro and haven't noticed it not coping...maybe when I thrash it on the track???
Post by SLYDIT » Fri May 09, 2014 3:22 pm
its the idle fuel pressure that get screwed up. the FPR cannot dump off enough flow to keep the pressure down to its correct level ...it should only be 35 psi and rise to 43ish psi off idle. with the 255 your fuel pressure will always be 43+ and the reg isnt actually regulating fuel at all properly at idle. you might not notice it if you have a full ECU but your idle tune will still be iffy because the fuel pressure wont be as consistant as it should be.
Post by Angreal » Fri May 09, 2014 4:17 pm
Not to my MX5 but to my work truck that had a new paint job done last week.... Dumped half a bag of iron oxide over it so my white car is now orange red. Did not go down well at the office :oops: that shit goes EVERYWHERE! especially when you lose 15 kg of the stuff out of the bag
Post by GRUVBB » Fri May 09, 2014 5:00 pm
Angreal wrote:Not to my MX5 but to my work truck that had a new paint job done last week.... Dumped half a bag of iron oxide over it so my white car is now orange red. Did not go down well at the office :oops: that shit goes EVERYWHERE! especially when you lose 15 kg of the stuff out of the bag
LOOK! It seems like it even landed on your Smiley face...... :wink:
Could be worse though.... You might have done it to your own car!
Post by SkilletKid » Sat May 10, 2014 6:47 pm
WideOpenThrottle wrote:skilletkid...Gonna strap that ducting to the swaybar WOT?
yep! something like that... will hopefully finish it today as I got sidetracked hunting down an oil leak which has turned out to be the inlet cam oil seal.
Keeping my fingers crossed that the crankshaft seal is OK!
Ahh cool would be interested to see pics when it's done.
Argh I know how you feel about oil leaks.... Fixed my inlet cam oil seal only to see a drip from somewhere else now. Have a feeling that the valve cover gasket doesn't like being torqued down, removed and torqued down again 10 times.
Edit: I took my car to the SCCNZ Ardmore Autocross today. Awesome fun. Only one other MX5 running there though.
Post by MrGrey » Sun May 11, 2014 10:53 am
I had a productive morning...
I started by installing some kenwood speakers a mate gave me. (the foam is 'vent strip' and is there to eliminate rattle from the door card speaker cover)
Secondly, I installed my gps holder.... the old mount for it had a suction cup that decided it didn't want to suck. so I made a bracket, painted it and covered the exposed bits in CF vinyl ... just because...
And this is it installed. Its actually really convenient now and to stop it shaking loose I have a large bulldog paper clip pinching it all together from the front (one of the old style black ones made of spring steel)
Post by 4A-GE » Sun May 11, 2014 2:01 pm
That foam in the door card thing is genius, I'm guna go do that.
Post by warrior » Sun May 11, 2014 3:21 pm
Try putting it where the speaker screws to the door as well
Joel
Post by Joel » Sun May 11, 2014 5:39 pm
Got my HAARTZ softtop installed yesterday, (what a massive pain that was)
and tinted my tail lights. Two things i've been avoiding for at least 6 months -_-
http://imgur.com/3UhCPqD
Post by MrGrey » Sun May 11, 2014 6:07 pm
nice work, I have heard that softtops are a nightmare to install and take many hours..
Post by Snapfrozen » Mon May 12, 2014 5:29 pm
Ooooh an update...
Well, the engine is baked, I've almost finished the monstrosity in the garage and went the other day to check some shit on the car and the battery was flat, decided I'd take it out and put it on slow charge while I'm working on the bitch. There's 2 reasons I'm glad I did this.
1. See below picture
2. This means I now have a chance to test the colours I wanted to paint my bay to get an idea of what they will look like.
It's been a while between updates so I'll let the pictures do the talking.*
Wire brushed the rust off
Dropped down some primer
Meanwhile I took to removing the bits that hold the battery in and hope they're not past best
The colour of them makes me wonder if the car either started life as a smurf/nigra or they've had to be sourced
I think to be honest, I'll be going black for the bay. Hides dirt, easy to clean and quite frankly, when I finally win lotto and paint the bitch, it will match.
The remainder of the bits all cleaned up. Nothing my dremel and wire brush and a rattle can couldn't fix...
And the finished result
I've got plans now to paint the entire boot. Car is being stripped for something fancy coming in a few weeks. Need to get her running first so thinking I'll paint the interior black to match.*
Here's a spoiler...
Oh... and I ate a 1kg burrito to get a free Lucho Libre mask at Mad Mex...
Post by MrGrey » Mon May 12, 2014 6:05 pm
nice work... and I have to say I really want one of those luchador masks.
my wrestling name would be "The ConquistaDork" :)
Post by GRUVBB » Mon May 12, 2014 6:23 pm
I reckon black will look the part. So its a vote from me to go that way!!! Keep the Mask, I want the Burrito. Tomorrow is $3 taco day so now you have reminded me I might go there for lunch. :o
Post by 4A-GE » Tue May 13, 2014 7:51 am
That's not a spoiler, it's a rollbar.
:roll:
jtsoldier
Post by jtsoldier » Tue May 13, 2014 9:10 am
4A-GE wrote:That's not a spoiler, it's a rollbar.
:roll:
I laughed at that far more than it really deserved...
Post by Snapfrozen » Tue May 13, 2014 4:44 pm
I did have to reread it myself cos I wasn't sure if I was telling people what it was...
Post by BRM » Tue May 13, 2014 6:52 pm
:roll:
lol
Post by 4A-GE » Thu May 15, 2014 5:52 pm
Added a foot of guitar cable onto my antenna cable and got my radio going again. Turns out there was a band expander sitting in there doing nowt. Also earthed... Something. Not sure what it was.
Hid the front end aux cable as best I could.
Did a skid, etc.
Post by BRM » Thu May 15, 2014 10:18 pm
4A-GE wrote: Did a skid, etc.
That's all you should have said.
Post by 4A-GE » Fri May 16, 2014 10:00 am
Forget it, images function has stopped working.
Post by warrior » Mon May 19, 2014 12:35 pm
Put my 25mm wheel spacers on and sorting a time out to get my guards rolled.
Also ordered some rev9 flares.
Post by BRM » Tue May 20, 2014 1:04 am
warrior wrote:Put my 25mm wheel spacers on and sorting a time out to get my guards rolled.
Pictures!
Post by warrior » Tue May 20, 2014 7:23 pm
Will put some pictures up over the weekend. Ended up buying my own guard roller as was not much dearer than getting it done, should get to me by friday.
