intake ports
na6*dori
intake ports
Post by na6*dori » Thu Oct 31, 2013 1:44 am
anyone know the factory measurements (ID) of the b6ze intake manifold? only need one of the four ports measured.... please?
Post by Furai » Thu Oct 31, 2013 7:45 am
What measurements do you need? I have one I can measure up
Post by Snapfrozen » Thu Oct 31, 2013 9:29 am
42mm wide x 25mm high if you don't include the small circle part at the top of the port. Just measured on my spare 89 NA 1.6 IM. Only 0.xx mm difference between that and the head and I've cleaned the IM but not the head so imagine the measurements are correct still
na6*dori
Post by na6*dori » Thu Oct 31, 2013 12:41 pm
thankyou
na6*dori
Post by na6*dori » Thu Oct 31, 2013 12:45 pm
would i be right to say that converts to a 42mm diameter circle by using the circumference?
Post by Snapfrozen » Fri Nov 01, 2013 1:20 pm
42mm wide, it's not round though..
na6*dori
Post by na6*dori » Mon Nov 04, 2013 11:59 pm
35mm i ment. as to work out how big i need to make my manifold to suit
