Rear Adjustable camber arms's
Post by REDBEN » Tue Oct 09, 2012 10:42 am
Has anyone tried or using the rear adjustable camber arm's from Redline performance?
Ben
Post by Bwarp » Tue Oct 09, 2012 11:14 am
Supposedly they're average as and have fitment issues.
Post by Kieran » Tue Oct 09, 2012 12:03 pm
You dont need adjustable camber arms on an mx5!! the eccentric bolts in the upper and lower control arms are adjustable from factory if you need more adjustment get offset eccentric bolts
Here
http://www.iscracing.net/miatasuspension.html
last_resort14
Post by last_resort14 » Tue Oct 09, 2012 12:30 pm
I brought some from redline a couple years ago, and returned them as they didn't fit.
Factory adjustment is only on the lower arms. And even with aftermarket lobe bolts wont give enough adjustment if your car is lowered.
Post by REDBEN » Tue Oct 09, 2012 1:58 pm
I bent the factory ones hence the replacement but if they are as you guys say they are I will be staying away from them. :o
Post by Kieran » Tue Oct 09, 2012 2:03 pm
Yeah if you want more adjustablity after offset eccentrics you have to extend the lower control arm to give more positive camber
last_resort14
Post by last_resort14 » Tue Oct 09, 2012 2:45 pm
^upper*
Post by sprsta » Wed Oct 10, 2012 7:21 am
here is a topic from a month ago
http://www.mx5forum.co.nz/viewtopic.php?t=10272
Post by Snapfrozen » Wed Oct 10, 2012 9:40 am
You also won't be able to certify them as it will throw you MILES outside the camber allowance (And for a WoF, you will have to if your WoF guy isnt a retard or the "let it slide" kind).
I've had to return about 3-5 pairs of camber arms from redline, each set lasted 1 race or less on my EG before they failed or bound (Yes, I used copper grease). Wouldn't touch them
Post by Kieran » Wed Oct 10, 2012 10:42 am
last_resort14 wrote:^upper*
God Twice! Heads not in the right place
Post by Euen » Wed Oct 10, 2012 12:49 pm
If you really want the extra adjustment you could go to the V8 Roadsters tubular arms from FM.
http://www.flyinmiata.com/index.php?dept=120
Post by Growler » Wed Oct 10, 2012 1:16 pm
Euen wrote:If you really want the extra adjustment you could go to the V8 Roadsters tubular arms from FM.
...or fabricate your own...
