how to remove trim at base of roof/boot lid +New paint pics
Hi, im about to start painting our mx5 and looking at what im going to remove and all looks easy apart from the hard plastic trim that runs around the base of the roof where it meets the boot lid panel.
I relly want to remove this as im changing colour and dont want masking lines.
Anyone know how its held on? glue,screw,clips??
Also anyone know a panel guy in CHCH that can help with filling the little dints as bogging is not my strong point! but painting im not to bad.
Jason.........
Jason.........
93 mx5 blue,
moulding
I was hoping that wasnt the case.
Cheers for that I guess i will unbolt the back of the roof enough to access as it as I looked again at taping it and not happy with doing that so its coming off.
Jason..........
Jason..........
93 mx5 blue,
paint
Going to use basecoat and clearcoat and we're going with the new mazda bright green (since seen they are doing a ltd edition new with that colour)
oh well should look pretty good I hope.
Will be starting prep this week and hope to be painting in 2 weeks I will take a few days off work and do the painting and assy over 4 days.
Heres a link of another one I found in the same colour
http://share.shutterfly.com/share/recei ... 265344bffb
93 mx5 blue,
trim
well after an hour of stripping the roof etc the moulding is stuck fast(only got the ends to move a little) so going to have to lift the rubber and mask under it its either that or destroy it getting it off!
The car is completely stripped and started the sanding so if weather is good painting on thursday/friday.
Got all the paint etc and that base coat/clear/thinners etc is damn expensive over $600 on a deal from the paint shop.
Will post some pics when all done.
93 mx5 blue,
Try a bit of heat gently with a hair dryer to soften it & work along from one edge as you go.
greenie
took the day off and finished up the green and layed a few coats of clear down and off the gun im amazed how flat i got it I though i would be blocking out orange peel for a day or so!
Letting it harden for a day then clear the underside of boot/bonnet and inside of doors which are all painted just not cleared yet then assemble at the weekend and snap some finished pics,
93 mx5 blue,
paint
Thanks guys Im happy with how its going so far.
To keep the dust down is hard I just swept and hosed the garage out between processes and have a couple of ol fans by the side door blowing some of the overspray out nothing fancy.
I use my gravity feed gun to paint it its only a basic gun i got a few years back for around $100 and borrowed a mates compressor.
I think using good quality (expensive as hell) products and not skipping any processes aong the way contributed to the good result.
93 mx5 blue,
"Rear Garnish"Angreal wrote:Silly question but how do I remove the piece that the number plate sits in that's located above your 2 doors?
Remove the number plate
Remove the 2 screws under the plate
Remove the tail lights (4 nuts, 1 plug on each)
Remove 6? i think nuts that hold the garnish in from inside the boot
Done! (From memory heh)
