Keys
thebears
Keys
Post by thebears » Sat Jan 14, 2012 12:20 pm
My original key split down the middle yesterday, and whilst bunnings managed to cut a copy to get me home i noticed the other spare keys i have don't open the boot, glove box lock or the cubby box lock behind the handbrake.
Does anyone know where to get a good replacement key that will work all locks??
Post by SLYDIT » Sat Jan 14, 2012 8:03 pm
you could try removing the drivers side door lock..it has the key code on it....
just take it to your locksmith and they will cut a brand new key...
the lock is easy to remove.
just remove the door trim and then use a 10mm socket to remove the two nuts holding the handle on, then un clip the door rod and your done..
