My baby has finally ventured outdoors
Post by Euen » Thu May 31, 2007 2:24 pm
OK, so it was on a trailer and she wasn't fully clothed but we're getting there. Had to take it up to Al's to get the exhaust done which is why the front bodywork is missing.
Although it doesn't look too much like a 5, the entire running gear is from an MX5, primarily from a '96 1800. If you want to find out a bit more about the TG, have a look at this month's NZ Classic Car magazine.
With a bit of luck I may be able to fire the engine up this weekend once I have navigated the intricacies of the Link.
Pic finally attached, apart from the filesize limitation, seems that they cannot be bigger than 1024x768 pixels.
Post by zorruno » Thu May 31, 2007 2:44 pm
what happens when you try to add an attachment? What file size is the pic?
Post by Euen » Thu May 31, 2007 3:35 pm
File size is 236K, jpg.
Browse to the file name, select it and press submit. Add Attachment box disappears and there is no indication that the file has attached.
E
Post by zorruno » Thu May 31, 2007 5:39 pm
It might not be intuitive enough sorry... just confirming the steps:
1. Below the message posting box, click [Add an attachment] button
2. Attachment adding box appears
3. Click [Browse] button
4. Find the pic you want on your PC & click open on the dialogue box
5. Add a 'File Comment' in the box if you like
6. Click [Add Attachment] button
7. Wait whilst pic uploads...
8. A new button now appears beside the [Add an Attachment] button labelled [Posted Attachments]
9. You can now either add more attachments, change the current [Posted Attachments]... or now [Preview] or [Submit] your new post
If after this, there is a problem, it may be due to file size (I can fix that for you), But you should have enough allowance.
Let me know if still a prob.
