Make sure that you have all your inventory filled with food and empty slots to stop him from pickingpocketing the thief without knocking him out first. This is if you're not worried about money and would like the highest possible level of Thieving EXP. The damage with OSRS gold will be incurred if you don't eliminate off the Bandit out, which is why taking food items will be essential.
When you have reached the level of 55 Thieving, you'll be able to begin Blackjacking the non-bearded Bandits within Pollnivneach City. This is similar to you would do with the Bearded Bandits method, as you simply lure them into any home to begin taking them out. This will bring you close to achieving level 65 quickly however you could be injured in the fingers.
Like the non-bearded approach it is recommended to have food in your inventory that has no empty slots to get the most EXP per hour, with no OSRS Gold gain.
Pickpocketing Ardougne Knights is the best option to get to the highest level of Thieving that is 99. This isn't AFK however, you'll need to click at that Ardougne Knight until you've reached 28 coin pouches. Making use of OSRS items during this process will boost the amount of EXP per hour.
The items that you should use include the Ardougne Cloak as well as The Dodgy Necklace.
This Dodgy Necklace will help you to avoid failure more often when taking out the Ardougne Knight. This also results in less damage overall.
Hiding the attack option will be a must in this moment and can increase the EXP/Hour significantly.
For this method to be successful it is necessary to locate someone among the Ardougne Knights that are located in Ardougne Square located in East Ardougne. Try to lure one into a home or change to the world 378 to locate an the already locked Knight in the northern house.
There are many players who will pickpocket one Ardougne Knight, and all you need be doing is get involved. Food is essential to recover, especially in the lower levels of Thieving.
Make sure you set your camera in a position where you simply click on the Knight throughout the day with no movement of your mouse. Bring a few fragile Necklace in your collection so you can get a new Necklace after destroying the previously equipped one.
The trapping of the Knight inside can be accomplished with a stab at any Ardougne Knight within the area Let him follow you to any residence, then shut the door.
Following that, you need to take a few tiles away of the Knight before beginning to steal from the Knight.
If you follow this method, you can expect to gain 70-230K EXP/Hour for Thieving depending on the level of your Thieving. After you have reached the level 95. the Knights will not be able to surprise you again.What's the reason I Still Play "RuneScape"
My favorite game is RuneScape for a while, but not regularly since 2005. It was first introduced to me by a good friend during my 13th birthday celebration. As we waited for everyone to arrive prior to heading to Dave and Buster's, he mentioned to us that we should see the latest game he'd just started playing.
My brother and I began with our personal RuneScape accounts within a couple of weeks.
In the blink of an eye, the procedure changed into the following: mine ores make smelt of ore to forge bronze daggers chicken execution with cheap OSRS gold, then sell the rest to the greedy clerk at the shop, and use the cash to buy tools. And on and so forth it goes on. As of now I've consumed all the energy drinks available I have available. I've never had to fight this intensely in my entire life to get rid of chickens. I took another bottle of red bull, knowing it could be quite a, hard night.
Rsorder Make sure that you have all your inventory filled with food
Users browsing this forum: Google [Bot] and 71 guests
