Mazdaspeed MX-5
Milford Autoelectrical
Mazdaspeed MX-5
Post by Milford Autoelectrical » Thu Jan 16, 2003 10:51 pm
Hi all,
I just got back from the Tokyo Auto Salon and have some good news for MX-5 fans that we are. In Japan you can go to your friendly Mazda dealer and buy a NEW MK 1 (1990 MX-5)1600 or 1800 Yes you herd right!!!
Mazdaspeed supply a secondhand car, strip it compleatly, then re-build it. You get a new interor with Mazdaspeed seats, instrument panel, soft-top all the rubber bits that perish, all new suspension, and rebuild the motor, and re-paint it, and there you have it- a new Mazdaspeed MK 1 MX-5. It is called the refresh program and is also available for the S6 Batman RX-7.
If anyone wants information e-mail me and i will try to scan in the info
Prices range depending on options ($25,000-32,000) for MX-5.
While in Japan i bought a set of HI/LO HID Headlights and all i have to say is YOU HAVE GOT TO GET THESE!!! They are so amazingly bright and worth every cent. The set-up wasnt cheap but, The bulbs are about $450 each and the balast is about $370 each and i used Hella semi-sealed lamps about $145 each. Fiting is a bit of a major but it is so good im going to order another set for my other car.
Right, time to go work on the car
Steve
lou Girardin
Mazdaspeed MX-5
Post by lou Girardin » Fri Jan 17, 2003 8:04 am
Just as I thought, the early ones are the only real classics!
Lou
Return to “2003”
