Isn't it great to be back at work again...Not!!
My wooden handbrake lever is starting to look a bit sad. The clearcoat is scratched off in places so I was thinking of removing it so I could strip it back. Has anyone removed theirs? and is it an easy job. I haven't had a really good look at it yet but there doesn't appear to be anything obvious holding it in place. Is it one of those brute force type jobs.
M@.
Handbrake lever removal
Yup brute force and twisting to get it off - good luke.
Matt; If you cant get the handle off (and some are really well stuck on)
its a simple job to remove the handbrake handle assembly. Undo 3 bolts,
unclip the cables and its off. Ross.
Is there a trick to getting the handbrake button off ?
ross campbell <mx5mart@paradise.net.nz> wrote:Matt; If you cant get the handle off (and some are really well stuck on)
