After some clarification on supercharger belts and the tightness of them.
I have been told two things, one that the belt should be as tight as
possible to avoid belt slippage etc, and two that the belt should not be
overtightened as it puts undue pressure on the front crank bearing? which
has a history of failing in early NA engines (apparently this was fixed in
later engines with a change to a larger crankshaft bearing???)
If anyone can clarify for me I would be very appreciative. I'm no
mechanic so not sure if the above parts are described correctly.
Duncan
From jifjif@gmail.com Fri Apr 27 18:35:36 2007
h=received:message-id
b=AtZHJ1NbIMpiRMg3SE18VGX8ZX+hMPQ75oNxLieSN6l6anB/Mp4lzNdZAtVFJwjuFJK7CYzcK16/sBFs1dOR7BDx/2k+fIsJjp75UZ2z1DzzvjdAMUZCJ0vZ7G0MFfa+VvoJlp1lQB+ByeRFlAuw+c+88Q1mbGsG5PvI0icVy1g=
Date: Tue, 7 Dec 2004 12:03:49 +1300
Subject: Re: belt tension esp. superchargers
In-Reply-To: <OFAF067E34.C6DAE67A-ONCC256F62.007CA4FE-CC256F62.007D073D@repnet.com>
Mime-Version: 1.0
References: <001901c4dbe2$e0bf9400$014665da@PC446628134234>
Message-ID: <07Lm4D.A.3lG.DpZMGB@L733>
hi Duncan,
Have you had a sniff around the sscor site/mailing list... and biggulp.net?
Sounds about right, although I've no first hand experience.
On Tue, 7 Dec 2004 11:45:33 +1300, dscotland@repco.co.nz
<dscotland@repco.co.nz> wrote:
