diff shudders
tiddy
diff shudders
Post by tiddy » Tue Jun 29, 2004 12:32 pm
anyone interested , the shuddering while turning tight lock at low speeds
in our diff was remedied by changing the oil to mazda spec limited slip
diff oil. the oil removed was clean and looked good but the properties are
crucial
ht
Voodoo
diff shudders
Post by Voodoo » Tue Jun 29, 2004 3:53 pm
What exactly is the "Mazda Spec Limited Slip Diff Oil" Brand, name etc???
crucial
ht
Tiddy Family
diff shudders
Post by Tiddy Family » Thu Jul 01, 2004 8:24 pm
voodoo
the oil came from a mazda dealer,(its mazda branded oil) its made for lsd's
, its expensive but very viscous and it does the trick
a 2 liter pack but you only need 1 liter
h
Fletch
diff shudders
Post by Fletch » Fri Jul 02, 2004 6:38 pm
Shuddering LSD's that get fixed with either LSD specific oil, or LSD
specific additive in normal gear oil, are only for clutch-type LSD's.
Early MX-5's had Viscous LSD's and later ones have TORSEN LSD's from the
factory. Neither of these types require, or respond to, LSD specific gear
oil... normal gear oil is fine. Neither factory LSD works on friction, and
thus, friction modifiers will have little if any effect...
The only MX-5's that will behave differently with LSD oil are ones that have
had a clutch type diff installed... the most common being a Mazdaspeed
item, or one from an RX-7...
Tiddy Family
diff shudders
Post by Tiddy Family » Mon Jul 05, 2004 7:22 pm
fletcher, you certainly appear to know your diffs
all i can say is my diff shudders have disappeared with this oil from the
local mazda dealer
dont know what was in the diff prior to this but the change is like night
and day
our car is a 91 v-spec
h
Voodoo
diff shudders
Post by Voodoo » Tue Jul 06, 2004 6:04 pm
Hi,
I actually went to Mazda today to find out about this. Its called something like "Mazda Slip Resistant LSD diff lube". Their parts system lists it as for "all rear end differentials".
My torsen has a whine under light throttle, so I am keen to try anything before having it pulled apart at great expense. Cost me under $30 for 2l.
I will report.
Gary
local mazda dealer
and day
h
Tiddy Family
diff shudders
Post by Tiddy Family » Wed Jul 07, 2004 10:35 am
hi gary
my packet of ltd slip gear oil part #K020w004525 cost me $42.75 incl
seems profit margins vary widely
hope it works for you
howard
Return to “2004”
