Cheers Glenn
That's saved a lot of effort and expense, I was just screwing round in the
driveway with the car lights, I put a 250mm wide piece of wood directly under
the lights and it cast quite a big shadow, enough to piss me off while driving
that's for sure. And I imagine it would be even worse with the 90mm lamps.
Looks like it's back to dreaming/thinking about replicating the Moss Twin
pop-up. I hate the factory ones as they stick up so high. Has anyone worked
out how they change the up/down travel on the Moss setup? I couldn't see from
the pictures if it was mechanical or they just adjust the existing mechanism
limits.
"PO1SON"
Headlight Question - Twin Headlights (Also a question for G
Re adjusting the up-down travel on the headlights - check this out on eBay.
http://cgi.ebay.com/ebaymotors/ws/eBayI ... l?ViewItem
<http://cgi.ebay.com/ebaymotors/ws/eBayI ... m=24848433
04&category=6755> &rd=1&item=2484843304&category=6755
