front pulley
Tiddy Family
front pulley
Post by Tiddy Family » Mon Jul 12, 2004 11:39 am
hi guys
my front pulley has got a wobble
is this a common fault on an older car or is it worth looking at a second
hand pulley?
do these puleys have a rubber center or something?
ta
howard tiddy
front pulley
Post by SLYDIT » Mon Jul 12, 2004 5:22 pm
if your talking about the pulley on the crankshaft
then you may have the dreaded "short nose crank"
failure. The keyway that holds the pulley on becomes
worn due to bolt or crankshaft nose failure. Incorrect
installation of the key steel when getting a cambelt
done has sometimes caused this. Id get it looked at ASAP!!!
Tiddy Family
front pulley
Post by Tiddy Family » Mon Jul 12, 2004 6:23 pm
do you know of any one in the waikato who's good at fixing this sort of thing?
ta
h
Janet & Jeff Curtin
front pulley
Post by Janet & Jeff Curtin » Mon Jul 12, 2004 7:00 pm
Re your wobbly front bit read this and associated links which are
mentioned.
http://www.miata.net/garage/hsue/LoctiteCrank1.html
Cheers Janet & Jeff
front pulley
Post by SLYDIT » Tue Jul 13, 2004 3:18 pm
Don McLean at Autoway services is your best bet in
Hamilton. Infact Hes running an mx5 technical day this
saturday at 2pm so you should come along.
Glenn "SLYDIT"
Return to “2004”
