broken. It cannot be opened using the inside or outside door handles. If I
take the plastic moulding off from around the inside handle I can see that the
metal rod still moves with the handle so perhaps the problem is at the door
catch end.
Has anyone experienced something similar? If so, any solutions would be most
appreciated, particularly, how can I open the door to take the inner liner off
to fix whatever is broken?
David Moughtin
From jifjif@gmail.com Fri Apr 27 17:56:46 2007
h=received:message-id
b=Q83aJqk24Npt4Y7JF7VW/sraTlNCaWMjOmF/yHsXv8JLIlGGYp1lBNg6g5erzVBnaClKVIzG5jxpbBiGH42BB2PLWPuKRvubfFP+KuFVn4PTRHeLj9xA+74FupHVmyfPVWrlJPg3B2YNwbOw7M5Pk7CZyCLOZ0rql6PEEr9g4fo=
Date: Thu, 27 Apr 2006 23:07:35 +1200
Subject: Re: Door opening mechanism
In-Reply-To: <001001c669e6$d8b6efe0$0100000a@lan>
MIME-Version: 1.0
References: <001001c669e6$d8b6efe0$0100000a@lan>
Precedence: list
Message-ID: <wL6jxC.A.HQH.bGZMGB@L733>
maybe a slimjim (not the biscuit!) or something similar? There's a
little lever near the B pillar that needs to be pushed... or pulled...
On 27/04/06, David Moughtin <Cola@paradise.net.nz> wrote:
