by 4A-GE » Sat May 17, 2014 2:24 pm
If the little lights up/hazard lights plug behind your centre heating console thingy is unplugged, your headlights won't come up when you flick them on.
Ask me how I know.
Also, carry around a pocket screwdriver set and a torch because if it's dark you're fucked.
by siren676 » Sat May 17, 2014 2:41 pm
You did what i did while doing a stereo swap
by Skilfil » Sat May 17, 2014 3:05 pm
siren676 wrote:You did what i did while doing a stereo swap
+1 to this, except I found out after finishing work at 10. Cue panic because I didn't have any screwdrivers, somehow my team leader in a call centre had one at his desk. Saved my ass.
- I only think 5.
by warrior » Sat May 17, 2014 3:06 pm
Same, thought i had broken something
- I only think 5.
by warrior » Sat May 17, 2014 6:22 pm
broomfish
by broomfish » Sat May 17, 2014 9:35 pm
Also, if the control relay under the dash becomes unplugged during alarm installation (apparently purely coincidentaly) the pop ups dont work, as me how i know ;-(
by 4A-GE » Sun May 18, 2014 10:22 am
My indicator relay came free during an alarm install. Dude who did it came around the next day to sort it out because I had no indicators.
If it were a big issue it woulda been free, but a quick easy free fix is always good.
Skilfil wrote:+1 to this, except I found out after finishing work at 10.
This was about 7, but still pitch black.
broomfish
by broomfish » Sun May 18, 2014 12:36 pm
Warlocks installed my alarm. Didnt find out till that night the lights didnt pop up, fortunatly i knew where the manual winding knobs were. Had a look under the dash the next day and the relay (right next to the alarm unit) was unplugged, phoned them and the guy was quite adamant it was a coincidence and not their fault, not even a sorry for the inconvieience.
by 4A-GE » Sun May 18, 2014 12:43 pm
We've established that they're dicks previously.
Ok, so, where's the manual winder?
broomfish
by broomfish » Sun May 18, 2014 12:49 pm
Pop the bonnet and on each headlight motor you will see a black rubber cover on top, remove that and there is a knob to manually wind the lights up or down. From memory the knob is red with direction arrows on the top
by marcellarius » Tue May 20, 2014 2:21 pm
The headlight retractors will match the correct state for the lights/switch, so manually turning the adjuster will make the motor kick in and retract them again. If you ever need to manually wind them up, pulling the retractor fuse in the engine bay fusebox lets you manually set the position.
broomfish
by broomfish » Tue May 20, 2014 6:01 pm
Or if the relay is disconnected or the pop up circuit is otherwise broken
Users browsing this forum: Bing [Bot] and 3 guests
