by Euen » Tue Sep 04, 2012 10:12 pm
Am in the process of rebuilding a rear subframe and have just discovered I don't have the bolts that hold the rear calipers to the uprights.
Before I go chasing off to Ross or Brownie, would anyone in the Auckland area have a set they don't need anymore.
by WideOpenThrottle » Wed Sep 05, 2012 7:39 am
Hi Euen
I may have some..would they be 14 or 17 mm socket head & how long a bolt?
Will search tonight after work
by Euen » Wed Sep 05, 2012 9:14 am
Full spec is M10 x 30 x 1.25 with a 14mm head. They are grade 10 bolts.
Thanks, appreciate your help.
E
- I only think 5.
by Donovan » Wed Sep 05, 2012 9:33 am
I most likely have them lying around, that I would have pulled off the NB, the trick is trying to find them. Did you want to pop around this weekend?
by Euen » Wed Sep 05, 2012 11:02 am
Can do. Will text you to sort out a time. Will be a good excuse to get the TG out again.
2low2c
by 2low2c » Wed Sep 05, 2012 11:18 am
i have a set here i am here till 7.00 pm every night if you want to stop by and pick them up.
by Euen » Wed Sep 05, 2012 12:11 pm
Thanks Paul. Will pop by this afternoon.
by Euen » Wed Sep 05, 2012 4:21 pm
Thanks Paul. Very helpful as always.
Thanks Wide Open Throttle and Donovan, I have a set now.
